Go Back  RCU Forums > RC Airplanes > Seaplanes
 Need basic parameters >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 08-31-2008 | 02:56 PM
Default Need basic parameters
I am thinking about scratch building a twin engine electric more like a seamaster not like a cub (what do you call each?) What are the parameters for hull width, length, angles etc.
Old 09-01-2008 | 08:31 AM
JimCasey's Avatar
Default RE: Need basic parameters
Most of what you need is here:
http://www.smilesandwags.com/Floatsite/westwood.html
Old 09-01-2008 | 06:33 PM
Although the article is difficult to read, the information will be useful. I have on question though. What is "dead rise"?
Old 09-02-2008 | 10:07 AM
Antique's Avatar
Follow these to the letter, never fails.
File Type: txt
Old 09-02-2008 | 08:38 PM
JimCasey's Avatar
Antique's attachment is a reference to Chuck Cunningham's landmark article which is the rosetta stone for float-flying. It is applicable to floats, but the article I sent has information pertinent to flying boats. ...Only one float-the fuselage.
Dead Rise , as I understand,is the angle the hull adopts when not making any lift. V-bottom hulls have deadrise, flat-bottom hulls don't, but they skip when they land.
Old 09-02-2008 | 10:51 PM
Jim,
I used the formula for a single float, the type that looks like a torpedo hanging under the fuse. The beam would be rather narrow, but the equation IS for a float not a hull. Could I widen it to what a normal fuse width would be?
The single float also has a larger portion of the float ahead of the step/CG than does the twin float arrangement. What would the ratio be for a hull design?
