Flat Bottom Floats
ON, CANADA
Flat Bottom Floats
Any plans for a set of flat bottom floats to fit a .46 sized plane would be appreciated. Also if you have any build photos, that would help to. Thanks
Jon.
Jon.
My Feedback: (26)
WI
RE: Flat Bottom Floats
What Jim said. The Cunningham design works great. On the 75% fuse length (determines the length of your floats), I tend to use closer to 80%. A little longer is better - especially forward of the step.
Hi guy's i have a good idea on making floats but would appreciate any pics or details on hooking up water rudder. I found an informative article on how to make them but not on hooking up the rudder on r/c groups but i'm not a member of that forum , Anyways this will be for a park flyer (Herr little extra w/ brushless). Thanks
My Feedback: (26)
WI
If your plane has a very large / effective rudder, sometimes you can make due without one. I flew a Cloud Dancer 60 with no water rudder, but sometimes wished I had one (wind).
Some people put a long wire with a rudder below their rudder. Then there's no new linkages.
I've used a mechanical linkage from the fuse connecting a pushrod. Lots of people use a nyrod (Goldenrod) from the rudder on the plane to the water rudder.
Some people use wires connecting the two, but that can be quite a project.
For 46 size flat bottom floats I cut the basic shape from foam (I use a hot wire but you could do the job by hand) & cover the sides in 1.5 mm balsa, in front of the step in 1 mm ply, behind the step in 1.5 mm balsa & use 3 mm ply for the top & back for strength to attach the legs & rudders. - John.
