Go Back  RCU Forums > RC Airplanes > Seaplanes
 Ace SeaMaster 40 kit >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 12-05-2009 | 05:19 PM
Default Ace SeaMaster 40 kit
I just scored a NIB SeaMaster kit.
I searched and didn't find much info on the kit, lots on the ARF. Have any of you out there built one of these? I'm curious about mods and weak points and such.
Thanks!
Old 12-05-2009 | 05:24 PM
goirish's Avatar
Default RE: Ace SeaMaster 40 kit
It's a pretty solid kit. However, I would re-inforce the pod area.
Old 12-05-2009 | 05:28 PM
Where the pod mounts to the fuse or the pod in general?
Old 12-05-2009 | 06:26 PM
goirish's Avatar
ORIGINAL: FentonFlyer
where it mounts to the fuselage. Sometime if not a perfect landing the pod will work loose then the prop may strike the top of the fuselage. Ask me how I know. BTW I am a Grand Blanc Boy.
Old 12-05-2009 | 06:30 PM
Okay, thank for the tip. I'm a Brighton boy, but I've been in Fenton for the last 10 yrs.
Old 12-05-2009 | 06:47 PM
goirish's Avatar
I'm now in the Hillsdale MI area for the past 25 years. Fly with the Balsa Butchers R/C club.
Old 12-05-2009 | 11:05 PM
It would be a good idea to reinforce where the rudder goes into the fuse.
Good luck
HughO
Old 12-06-2009 | 07:22 AM
Falcon6667's Avatar
Good on ya,,I have built several. An still have one, its been reinforced at the pod ,also i added one bay to the wing at the tip, it helped the flight a bit. its a really great flier with a 50 sayto 4st. i have seen them fly with as little as a 40 2st. We as a club (20 years ago) 6 of them, they all flew great..We glassed an painted the fuse, an used iron on for the rest. also you should think about putting a servo up front , maybe even 2 just to help with the slight tail heavy. with the new micro serves i would put one in the pod to operate the throttle.
If you would like some pics of mine i would be happy to send them e-mail or burn a disc for you.
Falcon
Old 12-06-2009 | 08:29 AM
Thanks for the replies fellas.
Falcon, Sent you a PM
