Anderson Kingfisher RCM construction article
<hr size="1" style="color: #a7a7a7; background-color: #a7a7a7" />Hi All,
A couple of mates and I are building the Anderson Kingfisher Amphibian from old Dennis Tapsfield plans and are in need of the RCM construction article.
Can anyone help me with a copy or a copy of the printed instructions sent with his plans?
Any help would be greatly apprieciated.
Best regards,
Hawk124
Best regards,
Hawk124
BC, CANADA
RE: Anderson Kingfisher RCM construction article
Hi Hawk
As we speak I am scanning the article,send me your email address and I will send it (Feb 1990).
Everyone there must love this plane ,there was a couple of guys from OZ,buddies of Brian Winch"s, brought some to our float fly on Shuswap Lake for a couple of years.
Cheers
Gregg
Cheers
Gregg
My Feedback: (41)
ORIGINAL: inroad
Hi Hawk
Everyone there must love this plane ,there was a couple of guys from OZ,buddies of Brian Winch''s, brought some to our float fly on Shuswap Lake for a couple of years.
Cheers
Gregg
Hi Hawk
Cheers
Gregg
If you can send to info @ slams.ca also
Hawk 124:
You need to get hold of Jerry Nelsons plans for the Kingfisher if you can. He may still have a set or two around. Dennis drew his plans from a three view and Jerry's are more scale with several advantages. Get a quarter scale Cub wing kit and save yourself lots of time. If you do Jerry's plane, I have a motor mount already welded up for it or a kit from 1/4" stainless you can build yourself.
Jerry's used pull pull cables for the ailerons, a little better engine mount, a better servo tray and such.
BC, CANADA
We have had some local people show up with those Kingfishers as well.
If Gregg doesn't come through I have a set of instructions I could copy.
Hi All,
Thanks for the responses to the above.
INROAD: Thank-you for the kind offer to email me the RCM construction article. My email is [email protected]. I look forward to hearing from you.
Chip_Mull: We have already started constuction with three fuslages underway. Thanks for the info on the Jerry Nelson plan.
bear57: Thank-you for your offer of a set of instructions. I'll take you up on it if Greg does'nt come through.
Best regards,
Hawk124.
Best regards,
Hawk124.
I have picked up a Kingfisher as well that needs to be finished and am looking for as much info as possible. If you still have that article scanned into your computer, would you mind sending it to me as well? Also, do you happen to know what the typical flying weight is on these and what gas engine people are using? Any help you could offer is really appreciated!
My e-mail is [email protected].
Mike
Mike
