RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   prop selection for float plane (https://www.rcuniverse.com/forum/seaplanes-176/1056136-prop-selection-float-plane.html)
IndyFlyer-RCU 08-14-2003 09:17 PM
What size prop should I start with on a SuperStar 40 with GP floats? I am powering it with a Thunder Tiger .46. Please help!
IndyFlyer
[email protected]
FLYBOY 08-14-2003 09:21 PM
10 x 6 prop would work great if it doesn't hit the water. Ge much longer and you won't get off the water because the spray will slow it down too much.
jrf 08-15-2003 08:05 PM
Prop
An 11x5 APC would be ideal. The larger diameter and lower pitch give better acceleration and climb performance at the expense of a little less top speed. Try that first and if it sucks up too much water, then go to a 10x6.
Jim
JimCasey 08-16-2003 12:58 AM
I agree with JRF: I'd use an 11-5 for a first try, just for the extra initial acceleration. You may find that a 10-6 is worth the extra flight speed, after you are used to taking off and landing on the water with the 11-5. I use an 11-4 on a Jerry's little boy with a 40FX.
IndyFlyer-RCU 08-16-2003 01:13 AM
10 x 6 I guess...
I have several 10 x 6s, so I guess I'll start with that!
