RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   Float Size (https://www.rcuniverse.com/forum/seaplanes-176/1978144-float-size.html)
retransit 07-10-2004 04:31 PM
Float Size
1 Attachment(s)
I would like some opinions on float size. Do you think these are big enough?
Bob
Oregon Craig 07-10-2004 05:13 PM
RE: Float Size
I would make them as long as the width of the swimming pool. :D
jrf 07-10-2004 07:06 PM
RE: Float Size
1)-It'll never get off the water, you don't have enough positive incidence in the wing.;)
2)-What will that Cub be when it grows up? It sure has big paws.:)
Jim
flynfish44 07-21-2004 10:46 PM
RE: Float Size
I think your floats must be leaking as it appears they have swollen a bit .
flynfish44 07-21-2004 10:49 PM
RE: Float Size
Or could it be the covering on the Cub is still shrinking in the hot son ?
Wayne22 07-21-2004 11:59 PM
RE: Float Size
y'know, if they were half an inch shorter, they might work :D
retransit 07-24-2004 02:40 PM
RE: Float Size
1 Attachment(s)
Here is the owner of the floats (first picture). Reunited as of this morning. Flew very Cub like with a Saito 1.20 at about 17 lbs. Will do a loop only after a spirited dive.
We managed to accumulate these seven aircraft at our weekly floatfly this morning. Usually it lasts about two hours. We must have been having fun because it went to four hours.
Ah, the site of a glass smooth landing. This is so much fun I think it may be illegal!
Bob
