RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   Coating inside fuse (https://www.rcuniverse.com/forum/seaplanes-176/649683-coating-inside-fuse.html)
jamcg 03-26-2003 05:08 AM
Coating inside fuse
I have a Hangar9 Ultra Stick 40 that I am putting floats on for my first float fly in April.
Question : Should I coat the inside of my fuse to waterproof (water resistant). If so, with what?
Thanks everyone, love your board.
James
WeLaserCut 03-26-2003 01:19 PM
Fuse waterproofing
You really do not need to waterproof the inside of your fuselage or wings unless you plan on playing submarine with your aircraft.
Unless you have a major crash (hope not) you are not going to get enough water in the fuselage to worry about.
If you do want to add something to give yourself piece of mind, some dope or thinned polyurethane works great.
FLYBOY 03-27-2003 11:07 PM
Coating inside fuse
I wouldn't waste the time, but if you feel you need to, you can thin 30 minute epoxy with alcohol and paint it on too. Make it thin like water.
Blackhawk RCU 03-28-2003 03:58 PM
"Coating airframes"
Don't bother on most airplanes. I have sprayed clear dope on 1/4 scale Cub airfames if it a dedicated float plane just to keep mildew out. A very light coat inside and out before covering, not really needed.
