Duralite ECU Battery Pack
My Feedback: (7)
My Duralite battery system has arrived for my Roo and I wanted to confirm that my Simjet 2300 ECU will be OK with an 11.1 volt battery plugged into it. I will be changing out the ECU and flight packs this weekend.
ON, CANADA
RE: Duralite ECU Battery Pack
Hi Brian,
So far I and several others are enjoying great success with Duralites for the SimJet ECU. The 11.1V pack is the correct one. The only bit of caution I would make is to disconnect the ECU from the battery during the charge process.
