SimJet Turbine Direct Support Direct support for SimJet Turbines provided here.
simjet 2300 power
Old 08-04-2006 | 03:55 PM
Default simjet 2300 power
I DONT KNOW WHAT HAPPENED WITH MI SIMJET 2300 , OR WHAT WAS THE PROBLEM WITH IT?
IN THE AIR LOOSE POWER AT FULL THROTLE , WITH GASOLINE ON THE TANKS, FULL BATTERY , BOTH NEVER THE TURBINE CUT OFF IN THE AIR .. I WANT TO KNOW WHAT
HAPPENED? . THE TURBINE LOOSE REVOLUTIONS AND WAS NOT HOT..
WHAT I HAVE TO DO?
PLEASE..
ALDO PACIFICO.
Old 08-04-2006 | 10:41 PM
Default RE: simjet 2300 power
Hi Aldo
What ecu do you have and what is the date on the sticker on the reverse side of the ecu. Have you tried doing any ground runs to see if you have air in the sytem? Do you have a solid radio link?
Ed
Old 08-05-2006 | 12:44 AM
CARS II's Avatar
My Feedback: (7)
Hola Aldo
Ed quiere saber see tenias burbujas de aire en las linias, si la maquina siguio trabajando sin pararse puede que ayas tenido aire en las linias o agua en el gas o tambien el filtro del gas esta tapeado de basura, revisalos.
Yo tambien tengo una turbina Simjet 2300, no he tenido ninguna clase de problemas con ella, hoy presisamente le puse tres vuelos con mis amigos, nosotros estamos muy satisfechos con estas turbinas.
si necesitas alguna clase de ayuda me avisas OK.
Old 08-05-2006 | 06:49 PM
hello ED.
TYPE ECU : FADEC 2002-D AND STIKER DATE 05/07 AND SIGN.. BY JV...
YES I HAVE A SOLID LINK RADIO...
THANK
Old 08-07-2006 | 07:07 AM
GRACIAS CARS II ..
POR TU AYUDA..
ALDO PACIFICO.
CCAS VENEZUELA.
Old 08-08-2006 | 06:42 AM
Hello Aldo,
Provided that you have no air in your system and the ECU battery is at 10.3 volts or higher with a load on it, the issue may be either a dirty fuel filter, or UAT (if you have one) or the fuel pump outlet pressure.
Before taking off, confirm that you are able to acheive the BLINKING Green light on the control panel at high throttle which indicates that your engine is meeting the performance expected by the ECU which indicates that you have acheived full RPM and power.
Brg.
Old 08-08-2006 | 10:10 AM
Thank kerry ...
I will be with care and check at that time..
Aldo Pacifico.
Caracas Venezuela..
Old 09-15-2006 | 01:15 PM
CARS II's Avatar
My Feedback: (7)
Aldo
Did you fix your problem with the 2300 loosing power?
Please let us know.
Thank you.
CARS II
Old 09-15-2006 | 04:56 PM
CARS II
NO YET , I´M REPARING THE MIG..
I WILL ADVISE YOU.
THANK
ALDO .
cARACAS. vZLA.
