repair simjet
Hello,
Today had serious trouble with my trudo 80, In flight had a flame out, when i landed i saw that the rear cone had seriously deformed an also the bolds of the cone inside where blown off.
I think the rear bearing has gone broke?
I experienced since a couple of runs that we had not the thrust we are used to.
Could the fault be the fuel pump , that we dind't had enough kero during startup? ( running on gas only)
So now
could i sent the turbine to the factory for checking ?
if yes
where do i sent ?
What do i send ( turbine , pump, ecu)?
thanks in advance
So now
if yes
where do i sent ?
thanks in advance
Hello Beljet.
I think I can tell you that It has nothing to do with the fuel pump. I can only speculate what happened to you engine.
But you need to contact Sandor, as the Trudo is sold through him.
