Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > SimJet Turbine Direct Support
 simjet 1200 18lb help needed >
SimJet Turbine Direct Support Direct support for SimJet Turbines provided here.
Old 12-29-2009 | 12:19 PM
Default simjet 1200 18lb help needed
hi could any one tell me if the 18lb simjet 1200 has the same shaft and bearings and turbine wheel as a wren mw54 as mine has lost one turbine blade and i think its going to need shaft ect the turbine wheel has mw54 on it []
Old 01-04-2010 | 07:53 AM
Default RE: simjet 1200 18lb help needed
zx6rg2
While the Trubine wheel "may" fit, the shaft is specific to SIMJET.
SimJet has manufactured their own Turbine wheel for the past several years as well.
It is important to carefully inspect the Bearing Shaft tunnel in an event like yours.
Where are you located ?
Please advise if I canbe of fruther help.
Regards,
Old 01-04-2010 | 02:46 PM
thanx kerry i have spoken to jacob today and i am sending him the turbine as he thinks thay dont make the parts to fix it any more it may be a scrap turbine [&o]
