8 Super TX with Multiplex Brick RX
Guys,
I am trying to drive a Multiplex RX with my 8 Super TX and have a small problem.
Everything is set-up Except the Throttle and Rudder channels appear to be swapped.
Is it possible to change the channel assignments of the 8S or am I stick with a duffer receiver ?
Regards
Paul
Regards
Paul
Hi Paul,
The easiest way would be if you are able to reach the receiver (assuming that it is installed in your aircraft) and just switch out the servo leads.
If this is not possible, I am sorry, this radio does not have the stick assignability of the 9Z.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
Thanks Krysta,
I had just about reached the same conclusion, unfortunatly you can't change the leads as the unit is one piece.
This is great for a Gas plane as the second servo is the throttle channel but in Electric you need the throttle to be a lead to the Speed Ctrlr [:@]
Shame as the unit is very well made and in a gas plane would be 110% but in a Twinstar or any other Big electric plane it's useless.
Again Thanks
Paul C
Again Thanks
Paul C
