Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Ultra Stick - Quad Flaps with 6XAS
Old 09-15-2003 | 10:02 AM
Default Ultra Stick - Quad Flaps with 6XAS
I'm purchasing an Ultra Stick 40 and I was wondering if I can set up the flaps to couple with the ailerons using a 6XAS transmitter?
Old 09-16-2003 | 11:20 AM
Default RE: Ultra Stick - Quad Flaps with 6XAS
Hi glowplug,
Unfortunately, no, the 6XAS does not have the mixing capabilities for an Ultra Stick 40, you would need to go to an 8 or 9 channel radio to get the mixing that is required for this.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 09-16-2003 | 01:19 PM
Actually, you can connect the flaps in the center to channel 5 gear switch. Although you will have no proportional flap control, you can then use the outer ailerons as spoilerons or flaperons.
You CAN do crow with the 6X, if you don't have retracts.
Old 09-17-2003 | 12:31 PM
Thanks Mike, I just got the same info from somebody else also......that's what I'm going to do.........until I get my 9C....
