Futaba Snap roll switch programming
1 Post
Hi all,
I am setting up a new model on my 9C and am having difficulties programming the snap-roll switch.
The mix cannot be turned on. When I try to activate it I only have OFF and INH values to choose from. The saftey feature is turned on, but the availability of the mix does not change if I change the gear switch. I cannot see any of the programmed mixes that are already using the switches that the snap-roll function is supposed to set up on either.
Any ideas? Thanks for your time.
This "General" radios forum is the forum this one is under. Here's the thread that was originally posted in the Radios forum:
http://www.rcuniverse.com/forum/rc-r...ll-switch.html
