 cai razor landing gear plate >
Old 06-09-2013 | 04:02 AM
My Feedback: (34)
Default cai razor landing gear plate
Hey guys. Just picked up an older jet from my boy at a good price. It's a<span style="background-color: rgba(255, 255, 255, 0);">cai razor with AMT 180 but one of the plastic landing gear plates are busted
anywone know where I can get one?
or where to get carbonfiber sheets to use with ply to make one?
thanks Mike<br type="_moz" /></span>
Old 06-09-2013 | 04:23 AM
Default RE: cai razor landing gear plate
http://www.cstsales.com/carbon_plate.html
Just Google "Carbon fiber plate".
Old 06-09-2013 | 04:27 AM
My Feedback: (34)
Thanks. So how dose one add up the .060 listed on the link? The plates are about 10mm
Would you use this with ply or get a bunch and layer it up?<br type="_moz" />
Old 06-09-2013 | 04:42 AM
smchale's Avatar
My Feedback: (67)
Mike,
You can try these guys:
http://www.dragonplate.com/ecart/categories.asp?cID=131
Also with a ply core:
http://www.dragonplate.com/ecart/pro...pID=571&cID=32
Old 06-09-2013 | 05:25 AM
LGM Graphix's Avatar
My Feedback: (22)
I believe it is details 4 scale makes a carbon fiber plate for the razor as well as the raptor. When I broke the plates in my razor I made new ones out of 1/4" ply and just laminated a layer of carbon cloth on each side. The plates are very thick where the retract mounts.
Old 06-09-2013 | 06:04 AM
My Feedback: (34)
Ok I've been thinking of getting carbon cloth. We're I'd the best place? Thanks
Old 06-09-2013 | 06:45 AM
smchale's Avatar
My Feedback: (67)
I've had good luck getting it here:
http://www.jamestowndistributors.com...x2+Twill+Weave
Old 06-11-2013 | 02:54 PM
I had hundreds of flights on mine. Just go with the 1/4" plywood and fly the crap out of it
Old 06-12-2013 | 08:07 AM
Guest
My Feedback: (73)
Agreed ... have carbon/composite plates as spares for my CAI Raptor ( Same plane but bigger) however I have been flying on plywood mounts without any issues. I fly mostly off of grass so that should tell you how they hold up
Voy
Old 06-12-2013 | 11:35 AM
My Feedback: (34)
Cool ill just use the ply.
Hey. Sence this bird has so much carbonfiber do I need to use the spectrum carbonfiber recivers?<br type="_moz" />
Old 07-09-2013 | 11:28 AM
My Feedback: (34)
Anyone out there got the CG and throw infomation?"
Please......
Old 07-09-2013 | 11:44 AM
Hi Mike,
You can go 1/2" up/down on the ailerons, 1-1 1/4"up/down on the elevator, 60-70 degrees on the landing flaps...no more or it becomes a brake The more rudder you can get the better... like 2'' and then use your rate switches from there. I set all my controls max throw till the servo buzzed and then back it off a little to quieten things down. Set your nose gear on a separate knob to trim by itself. Call me with any questions at 903-496-2939 Great jet, you'll love it.
Jack
Old 07-09-2013 | 11:46 AM
My Feedback: (34)
Sweet. CG?
anyone got an exstra set of stock nose gear doors?<br type="_moz" />
Old 07-09-2013 | 01:26 PM
I seem to remember that it is on the front of the cover plate for the retract cover. Take a pic of the bottom and wing and I am sure I can remember. It was either the front or back but once I look it should be obvious to me
Old 07-13-2013 | 04:10 PM
I just saw a friends he is about to fly. CG is on the front of the gear cover plate for retract unit
