148 DF Question
My Feedback: (25)
TN
I have a 148Df Receiver that I am using on a UCD46 and I am using CH2 & CH8 to run two servos for the elevator using the Ailevator function. The question is does it hurt to plug the battery into CH7 since one of the elevator servos is plugged into CH8 which is where the battery in suppose to go?
Thanks, Fossil
Thanks, Fossil
Hi Fossil,
No, this will not hurt the receiver, you may plug the battery into any of the channel ports you like without worry.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
