3pk question
I have a new 3pk. I am trying to change the neutral of my throttle. Otherwise nuetral on the trigger right now is half throttle where as I need it to be near idle. This is for a boat so I dont need very much back trigger (brake) just enough to kill engine. If I can get the trigger to give full servo throw in the forward "accelarate" position I will be in business.
Mike
Mike
Hi Mike,
You will need to go into the Adjuster menu on your 3PK, this will be in Menu 3. From here you just need to select Throttle, when you get into the menu, you will see an arrow flashing by the word "Neutral", with a set percentage in parenthesis. At this point, just move your throttle to the desired new Neutral point and press the two set keys at the same time.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
Thanks Krysta,
I tried that, here is what is happening. I went to adjuster menu, selected throttle and the neutral menu came up. I then moved trigger back so the neutral was where I wanted and pressed the + and - keys. Nothing happened. The only key I can press and make something happen is the "sel" key. Once I do that the brake and forward menu comes up after I go through these, it said system failed, did not adjust.
What am I doing wrong?
Mike
Mike
