Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
New 6xas help
Old 10-08-2003 | 11:42 AM
Default New 6xas help
I have just purchased a new 6xas, my first computer radio.
What should my initial settings be on this radio?
If i neutralize all of the settings on the planes themselves, do I also set the radio functions at neutral?
Al
Old 10-10-2003 | 01:13 PM
Default RE: New 6xas help
Hi Al,
If the 6XAS is brand new, then it comes with all the defaults aleady set. This is your starting point for all control surfaces.
You will need to make sure that your control surfaces are physically set to as close to perfect as you can get them, and then if there are minor adjustments needed, you can then change the ATVs. Trims, and Subtrims where needed.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 10-11-2003 | 09:25 PM
Thank you for your help, I'm sure this will get me started.
Thanks again
Al
