Problems with flaps in Flaperon on Futaba 9CAP
My Feedback: (135)
MA
I have Flaperons set up using Channels 1 and 6. That works fine but I am having problems getting flaps to work. The only way I can get it to work successfully is using Airbrake. That's fine but it only works on the lowest position o the 3-way switch "C" which I use for throttle down and Throttle cut.
How can I assign this function to another switch? I can't find the screen to do this.
Hi Meesh,
The easiest way to do this would be to make Flaperons active, then go into Flap mix, set your percentage to how much flap movement you want. Next go into AUX channel and assign channel 6 to a different switch say switch A. Now you should get aileron movement from your stick and Flaps will work from whichever switch you have chosen.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
