ailervators to knife edge mix problem 9cap
when i set up ailerators mix and then set up knife edge mix eg rud to down el and rud to ail on premix 6 and 7 only one half elevator responds do i have to do a auix 1or 2 mix!
Hi negy1,
Are you using a Pmix for your Ailevator function, or are you using the Ailevator mix? If you are using a Pmix, for this set up then you will need to link the mixes 6 and 7. If you are trying this only with Ailevator mix and then the 6 and 7 Pmixes and it is still not working for you, I would suggest that you go into a blank model and retry this set up as you may have another mix turned on which is inhibiting this action.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
yes was using ailerator mix i reprogramed mix 6and 7 set trotle as master at 35% throtle at null so mix is on permently after 35% but done inishial test throught switch F so i could switch of if wrong then land and reprogram until i am satisfied works great thanks
