Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Using 9C sliders to change top end rotor pitch on heli
Old 12-14-2003 | 04:59 PM
Default Using 9C sliders to change top end rotor pitch on heli
Hello,
I was told the 9Z has a factory installed mix that allows you to vary the high end pitch of the heli rotor blades. Will the 9C allow you to program a mix into it that lets you do the same thing?? I want to be able to use the right hand slider to allow me to change my top end blade pitch one degree on either side of 9 degrees.
Old 12-15-2003 | 12:47 AM
Default RE: Using 9C sliders to change top end rotor pitch on heli
I figured a way how to do it. VR(e) slider moves the pitch curve at both ends--which is pretty close to the original request. The mix actually allows one degree of pitch in both directions and at each end of the pitch travel. I have +9 on top and can now vary that between 8-10 degrees. Same on the bottom.
