Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
TX/RX Compatibility
Old 12-16-2003 | 11:17 AM
Default TX/RX Compatibility
I currently use an FP-TK-FM module in my 8UAPS TX along with a FP148DP Rx.
I also own a Futaba T5UAP/PCM1024 Transmitter. Can I use the FP-TK-FM Module in my 5UAP/PCM1024 TX?
Thanks for the help
Old 12-17-2003 | 01:07 PM
Default RE: TX/RX Compatibility
Hi Cassidy,
Yes, while the module is designed for the 9V and 9Z radios, you will be able to use it in your 5UAP.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
