RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
bow ties?
Old 07-18-2005 | 11:32 PM
brownstone101's Avatar
Default bow ties?
hi guys i need help my fronts are all cracked and a little worn. so i was wondering whats a good tire for the front would be. i dont want the edge from pro line again cause i didnt like them that much. i have a set of pro line bow ties in the rear and my wired stock safety pin tires but there for bashing not racing would bow ties in the front with new rims would be good ??
thanks
link me too if u feel like it
thanks
EDIT no typos but needed some.......
Old 07-19-2005 | 03:09 PM
Default RE: front tires need help
man what dont get is why no one likes me [] i try to help every one and i hardly get looked at[] please i need help i just need to know if bow ties work good in the front thats all please[]
Old 07-19-2005 | 03:15 PM
Jamxx's Avatar
Default RE: bow ties?
I've seen them often in the front and back together. They're really good tires, so I'd pick some up. I've never used them, though.
And I don't think it's that no one likes you, I think it's that no one that viewed this thread had any idea about it. I did earlier, and since I didn't know much about these tires, didn't bother responding. But now since you asked, I responded.
Hope that helps.
Old 07-19-2005 | 03:21 PM
ya i have seen them on the fronts before too there nice tires but i just was wondering how well they were in the fronts
and i changed the name of the tread so more people will maby look
thanks
Old 07-19-2005 | 03:36 PM
ORIGINAL: brownstone101
thanks
i like you avatar lol
Old 07-19-2005 | 03:43 PM
D0G
Ive actually put worn Bow tires on the front of my Evader. My thoughts on that are this...They Grip very well, and IF...IF your car is balanced properly they will work great. What I found personally was that the front wouldl ift off the ground just a lil, then when it would touch down again the turn would be to much...I mostly ran on grass so the traction was to much ( I thought). I found that I couldnt control the steering, it seemed very erratic and was hard to keep straight. Also, I had a few broken parts that I found after that, so that ay have been the issue. It looked cool, and I think that if you had 2 sets both front and back ...brand new I think that it would look pretty sharp.
Speaking of tires, When you guys say that those Road rage tires or w/e they were called are the best....thats rear tire....what would you run for the front tire?
Old 07-19-2005 | 03:56 PM
I used to run road rage tires...and for an ST, road rages work best when they are all around the car. Being treaded street tires, the road rages grip best on road...so why put aggressive steering edges up front mainly for dirt, when you run in the street. I ran them on all four tires, and i instantly noticed a difference from the stock tires. Hope this helps.
-andy
Old 07-19-2005 | 03:57 PM
I try to help you, but i can't understand what you are asking. Youre posts are one continous sentence with lots of mispelling and next to impossible to understand. If i could understand what you are asking i would be more than willing to help.
Old 07-19-2005 | 04:04 PM
uhh me or D0G i fixed mine u can read mine D0GS is hard
Old 07-19-2005 | 04:26 PM
You i could read dogs.
Old 07-19-2005 | 05:09 PM
o ok
let me edit it better ok its edited now it makes sence i was realy tired when i made this so i didnt catch that NP
Old 07-19-2005 | 05:16 PM
When i start racing i'm going to be using gladiators all around. Some people at my track use that setup and really like it.
Old 07-19-2005 | 05:28 PM
that was what i was also thinking pulling off the bow ties on the rims i have putting bow ties up front
by gladiators and put them on those rims in the rear and buy new fronts dish rims sound good??? or bow ties all round
Old 07-19-2005 | 05:31 PM
never mind im getting bow ties all round
how long do they last in the front? the edge ones lasted forever how would the bow ties hold up
Old 07-19-2005 | 05:32 PM
What surfaces will you be running?
Old 07-19-2005 | 05:40 PM
The_Collector's Avatar
I often used PL Dirt Works in the front. They last a while and look more scale.
uh hard pack with a light layer of that clayish sand grit stuff
Old 07-19-2005 | 05:47 PM
ORIGINAL: The_Collector
For racing???
Old 07-19-2005 | 05:58 PM
Yes, or I'll use the blade. There is a reason why the pro's don't use pinned of spiked tires in the front.
Old 07-20-2005 | 06:16 AM
gerwen's Avatar
Bow ties are meant to give their best traction in the front/back direction, they aren't meant for non-drive tires, and your steering will suffer if you put them on the front.
Edge type tyres are designed to grip in the left/right direction to maximize steering. They will probably be your best bet on most types of dirt.
Old 07-20-2005 | 10:55 AM
A lot of tracks are now running rear tires in the front im not sure on the exact reason why, but it seems to work.
Old 07-20-2005 | 03:36 PM
GoldenPoint's Avatar
GET THE PROLINE BLADE!!! its half ribbed and hav squared its really good for almost evrything! http://www2.towerhobbies.com/cgi-bin...?&I=LXMW77&P=V
Old 07-20-2005 | 05:39 PM
i got bow ties and new rims hay i will learn if its a good thing or a bad and if its bad o well tires are tires better than rims lol
i will get pic of it and how sweet it looks with them on
Old 07-21-2005 | 12:12 AM
ok
THE TIRES ARE SO SICK
1) they look sweet
2) they bite the ground
3) as good or better than edge(looks better to eye candy)
4) look at the PIC OYA i recomend bow ties up front and u need to have it set nice, but they are a very nice tire 10/10
ID:	299746   Click image for larger version
ID:	299747   Click image for larger version
ID:	299748   Click image for larger version
Old 07-21-2005 | 12:23 AM
ORIGINAL: losi xxx-ntkid
thanks
o ya thanks lol i got alot of funny ones
