RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
many nitro questions
Old 07-24-2005 | 08:27 AM
StOcKerRaCer's Avatar
Default many nitro questions
I might get a nitro and I have my eye on a xtm xcellerator and I have questions=
1.How long is break-in?
2.how long does a tank of fuel last?
3.how many tanks are in a gallon of nitro?
4. how long do glowplugs last?
5. How much does maintence cost?
I probialy have more questions but that's all for now
Old 07-24-2005 | 08:53 AM
Default RE: many nitro questions
1. About a quart of fuel, or maybe about 8 tanks.
2. 6-10 minutes depending on tune
3. A lot
4. Depending on tune, glow plugs can last anywhere from one tank to several gallons. I've heard of someone's OS A3 plug lasting 8 gallons. On average though, a plug might see 1-2 gallons.
5. As long as you have the right stuff, maintanance shouldn't cost you a thing. That is unless of course you plan on letting the LHS do all the dirty work.
And by the way, this is the forum you should be at. http://globalservices.globalhobby.co...wforum.php?f=9
Old 07-24-2005 | 09:05 AM
ok thankz for the reply I thought glowplugs lasted only 1 tank [sm=spinnyeyes.gif] and how fast can it go? I heard over 60 they said but I know all the manfuacters do that
Old 07-24-2005 | 10:15 AM
monsterpede360's Avatar
yep he is the man to talk to.
Old 07-24-2005 | 10:33 AM
do I need a temp gun for break in???? me and my broke self could buy a gallon of nitro for the price of a temp gun [sm=bananahead.gif] and how long until I need a new piston and sleeve?
Old 07-24-2005 | 10:39 AM
peed's Avatar
ORIGINAL: StOcKerRaCer
no, it wont go 60 out of the box, like you said manufacters always say that.
i think Valve gave you the perfect answer, but this is what i think:
1)4-6 tanks
2)onroad it will last around 6 min, of road 6-10
3)40-50, also depends on the size of the fuel tank.
4)definately depends on tune.
5)depends, if you want to start upgrading, it will cost, but like in every car, maintence costs.
hope that helps
Old 07-26-2005 | 06:13 PM
re question 3(how long does a gallon of fuel last)
1 gallon=4500 cc
my tank(not all the same size)165cc
4500/165= 28 fuel tanks
But as alex7 said depends on the size of fuel tank and engine size/tuned state
Old 07-26-2005 | 06:16 PM
sorry meant ml(milli litres not cc)before i get corrected!
Old 07-26-2005 | 06:21 PM
now I am looking at a used t-maxx and thanks for all you guys help! RCU rocks!!!!
Old 07-26-2005 | 06:34 PM
peed's Avatar
np man, if you have any other questions just ask
btw, how much are you getting the maxx for?
Old 07-26-2005 | 06:38 PM
I am obviously biased but me and my mates have between us,1 2wd buggy.1 4wd buggy.2 2wd stadium trucks.2 4wd monster trucks. 1 1/5 th scale fg marder.We all agree (depending on the terrain) a 4wd monster truck is the best package.I would decide mainly on where you are going to run it.flat 2wd.hills rough 4wd...........
Old 07-26-2005 | 06:42 PM
I am getting the t-maxx for 100$ it runs good and I am getting it from my lhs so I can make sure it runs before i leave
Old 07-26-2005 | 06:44 PM
waht is the signs that I have to lean it out or ritchen it up?
Old 07-26-2005 | 07:00 PM
peed's Avatar
how?, you mean lhs(low speed needle) and hsn(high speed needle)?
Old 07-26-2005 | 07:15 PM
yea like if it wants to bog what to do etc. [I am asking because my t-maxx most probialy won't come with a manual]
Old 07-26-2005 | 07:18 PM
IBrakeForNobody's Avatar
My Feedback: (16)
IMHO...
1. 4-7 tanks
2. 3 mins to 15+...depends how you drive
3. Assuming you want a nitro st, a fuel tank capacity is 75cc. One US gallon is 128 fl. oz or 3,785.4118...cc's. So, there are approx. 50.4721573 tanks of fuel in a gallon. For a 125cc T-Maxx tank, its about 30.2832944 tanks.
4. I have about 15 tanks through my RC10GT, and still have to burn out the stock plug...did break in with the same plug as well. But, I've seen plugs last two seasons.
5. Pistons/Sleeves/Connecting rods are fairly inexpensive for stock engines...with a high quality engine (OS etc), its essentially cheaper to get a new engine. Other than that, you'll need after run oil, and air filter oil, and other stuff, which lasts quite a while...I've been using the same bottle of after run oil in all my nitro RCs for over a year.
6. Its handy to have a temp gun, but the water drop method is suffecient enough...but a temp gun would be A LOT of help...
7. You'll need a new piston and sleeve about every 3-8 gallons.
Old 07-26-2005 | 07:19 PM
peed's Avatar
that sucks, it think that if you are buying the maxx you should get a manual, just to be prepared for anything, or to reset everything, etc.
Old 07-26-2005 | 07:38 PM
I might order a manual from tower if it dosen't come with one
Old 07-26-2005 | 09:32 PM
how do u take off the diff. on a nitro truck. thanks
