Tires return to left?
Hi,i connected my electronics,and im happy with the bluebird 195oz servo for steering.Now nomatter howmuch i adjust the steering trim,the tires turn nomatter if i turn them to the left or right they always return to the left a by quite bit?Whats my problem?I have the TF-3 radio and reciever. Thanks.
ORIGINAL: naynay12
After that, see if you still have the problem.
Ok,but how am i suppose to center the steering trim on the radio when the servo wont woik since the arm is off?Is the arm the horn?
ORIGINAL: naynay12
Something like that happened to me once. I finally figured out that one of the switches on the tx was in the wrong position. I dont know if that will fix it for you but its worth looking into.
I wasnt talking about wires but a switch on the remote. When it happened to me it would turn really wide one way but hardly the other way. I hadn't touched anything on the truck and all of a sudden this started happening, turns out the switch was moved while it was in my backpack.
