HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Recharging receiver bat.
Old 05-05-2007 | 02:24 PM
Stablock's Avatar
Default Recharging receiver bat.
Put it on the peak charger and went out to cut the grass. I came in and asked the wife if she heard my charger beep. She said "No but I heard a loud bang!" Check it out!!! Well, I'm just glad I didn't have it in my truck when it happened!!!!!
I'll never charge it in the truck EVER now!
ID:	678201   Click image for larger version
Old 05-05-2007 | 04:59 PM
97talontsi's Avatar
Default RE: Recharging receiver bat.
LMAO
doesnt the peak charger stop it when it gets hot
what charger do you have and what settings did you do?
is that why you had to use the AA's in the RX?
I do a slow charge takes about 3-4 hours
Old 05-05-2007 | 06:03 PM
Foxy's Avatar
Charge them at the same amperage they discharge...eg 1400mAh, charge at 1.4A for 1 hour. Simple. Don't charge rec packs over 2A though. I would blame the charger, maybe the peak detection circuit has had it.
Old 05-05-2007 | 06:41 PM
DaveG55's Avatar
A peak detection charger watches the charge current and battery voltage. It does not detect heat (ok, well some will but not most) so if it was charging too hard it could easily overheat and explode w/o tripping the peak detection circutry.
You did not say what charge rate you had set but as foxy said charging at 1C is about the best balance of time and rate.
Two other quick thoughts...They say not to charge a battery unattended for a reason and second, aren't you glad it wasn't a lipo?? If one of those had done that it would probably have started a pretty good fire.
Old 05-05-2007 | 06:45 PM
DaveG55's Avatar
One other thing,
The rating on the pack 1400mah say, is the capacity and not the discharge rate. While it could discharge at that rate it can also discharge at a much lower or higher rate. The difference being how long the battery would supply power at the actual discharge rate. For example a battery rated at 4000mah will delive 4000 ma for 1 hour, 2000ma for 2 hours or 8000ma for 1/2 hour, etc.
The rating 1C describes the current that it takes to charge a battery in 1 hour. so for a 4000mah battery the 1C rate would be 4 amps.
Old 05-05-2007 | 06:51 PM
Foxy's Avatar
ORIGINAL: DaveG55
One other thing,
Thanks for the correction, you know what I meant, I just used the wrong terminology. Iknow how it works, I was just typing quickly and typed the word that came into my head. I also forgot the 'C' unit for charge rate, I should have mentioned that too. Anywayz, hopefully OP is now informed.
Old 05-05-2007 | 07:29 PM
Stablock's Avatar
Attached is the charger I used. It was on for about 15 minutes when it happened. It was at 1 AMP.
Yes, that's why I was running AA's that day. Bought a new bat and charger from Golden Horizon for $25 cash.
Old 05-05-2007 | 07:37 PM
Foxy's Avatar
I think you should shell out for a better charger if you want to avoid such incidents in the future.
PS Peak Prediction?!! Woah, a psychic battery charger!! Most wait until peak is reached before deciding to turn off. Maybe it's psychic lowers let it down on that one.
Old 05-05-2007 | 09:27 PM
TheOtherSide's Avatar
Wow... that sucks.... good thing it wasn't in the truck. I use a super slow charger that takes 12-14hrs...
Old 05-05-2007 | 09:36 PM
Stablock's Avatar
ORIGINAL: foxy42
This IS a peak charger.
http://www.dynamiterc.com/Products/D...ProdID=DYN4036
Old 05-05-2007 | 11:11 PM
rclynx's Avatar
Just a quick funny story about charging an ingiter with almost the same results. A month or so ago I had a lot of people in my shop and after they bought a few things and left I was quit upset because I thought they had stollen an igniter I was charging, the cord was hanging over the stand where it was when it was charging. The next morning I came walking into my Hobby shop and noticed way accross the room was an igniter laying on the floor and as I walked over I was thinking that was strange till I picked it up and the whole top was blown wide open. Made me feel bad about thinking it was stollen. Its just happens like that sometimes. I have batteries charging 24-7 and I don't care about being there and attending the batteries when there charging. What if I was there and the darn thing hit me in the head[] That wouldn't tickel[&o]
Old 05-06-2007 | 05:07 AM
Foxy's Avatar
ORIGINAL: Stablock
ORIGINAL: foxy42
I know it's a peak charger (or at least it thinks it is), you've quoted me above and note that I didn't say anything about it not being a peak charger, I was laughing at the wording. Prophet, peak PREDICTION lol! I'm just telling you to get a better one. $60 for a charger is false economy, trust me.
Old 05-06-2007 | 09:00 AM
Vigilante212's Avatar
My buddy gave me a prophet plus for free so ill use it . Im almost always in a hurry so I charge my batteries at 4 amps for a quick charge. I know I shouldnt, but when you have 2 hours and 3 batteries to charge you really dont have alot of options.
I do remember being young 12-13 I had gotten a tyco rc car it was fast for a cheap car. I was charging the flat cell pack behind the couch one day when it started smoking and making poping noices luckily I got it outside before it started a fire and tossed it int he snow bank . Just trying to say even for a purpose built charger sometimes the battery packs go to hell.
Old 05-06-2007 | 11:03 AM
When you buy a charger, one thing to look for in the specks is, short protection or detection. You have a good charger (I have one) but your battery was probably getting week and a sell shorted out, the charger didn't detect it and kept charging and Booooom. It can happen with any charger that doesn't have short protection or detection, regardless of $$$ spent. Another good thing to look for is cross polarity protection.
Old 05-06-2007 | 11:36 AM
Stablock's Avatar
Well, I'm not looking to buy a new charger as I already have this one. But I did buy a new hump pack with slow charger. So I'll just use that. But I still will not charge it in the truck. Thats for sure!
Old 05-06-2007 | 12:41 PM
LoL sorry but that is hilarious. "Honey, did you hear my charger beep?" "No, but I heard an explosion."
Old 05-06-2007 | 03:47 PM
A1Viper's Avatar
ORIGINAL: lpa12threh
I wasn't going to say anything, but...What he said! LOL
Old 05-06-2007 | 05:04 PM
Stablock's Avatar
this is what I'm saying!!!
Old 05-06-2007 | 07:17 PM
http://www2.towerhobbies.com/cgi-bin...7&I=LXCLD5&P=K
I ordered this charger for my preparation for a Savage. To use this for charging receiver packs, is it a good idea to charge it at .7 or .8 amp to play it safe?
DuraTrax Piranha AC/DC Digital Peak Charger NiCd/NiMH
