HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
axial 28
Old 05-09-2007 | 12:58 PM
lauderboy's Avatar
Default axial 28
i hoped 4 more power its fast but no wheelies
ne tips it runs on 30%
Old 05-09-2007 | 12:59 PM
Foxy's Avatar
Default RE: axial 28
what gearing?
Old 05-09-2007 | 01:01 PM
Mine wheelies almost too much with 18/47 and front ext TVP's... I was unintentionally wheelying at like 1/2 throttle on the first break-in tanks...
Old 05-09-2007 | 01:31 PM
lauderboy's Avatar
17/52 i think
Old 05-09-2007 | 01:43 PM
Foxy's Avatar
Maybe you just need to tune it.
Old 05-09-2007 | 01:49 PM
lauderboy's Avatar
i have its tuned sweet but still no wheelies
my k4.6 with the same gearing was very good
Old 05-09-2007 | 03:43 PM
ThunderbirdJunkie's Avatar
if anything the Axial has MORE power than the K4.6. they're very similar engines.
does it run funny? any stuttering at WOT or anything like that? does it idle high? sounds like it isn't tuned right to me.
Old 05-09-2007 | 06:39 PM
black mamba's Avatar
Something is not right with your setup. Your truck should be popping wheelies all the time, regardless if at a stop or already rolling. What clutch are you using? If you are using plastic or carbon shoes, dump them and get aluminum ones. What gearing? 17/47 is a good place to start. How tight or loose is your slipper? Keep it on the tight side-mine is as tight as I can get it. Too loose and it'll just slip all that Axial power away, not to mention destroy the slipper pad.[8D]
Old 05-09-2007 | 06:41 PM
Oh yeah, make sure your carb is opening up all the way at WOT. If not, that will kill power big time-adjust the linkage until you get the carb's slider all the way open.[8D]
Old 05-09-2007 | 09:12 PM
just finished breaking mine in and it wheelies like nothing and i still have to lean it out some more. I dont want to gun it too much yet. but i still gun it more than i should. my setup is an X SS
Old 05-09-2007 | 09:21 PM
SAVAGEJIM's Avatar
The Axial .28ci and K4.6cc are just about identical engines down to the timing profiles. The only differences betwen the Axial .28ci and the K4.6cc is the Axial engines have the leading edge of the crankshaft cut with a scoop and the crank shaft 14mm diameter has 2 oil grooves instead of the K4.6's one oil groove. The Axial engines also have carb ventri inserts (I think) so you can choose between 8mm, 8.5mm, and 9mm (I cannot remember if these diameteres are correct). Also, the Axial engines use 2piece head button and heatsinmk and you can use tubo plugs with Axials where you cannot with the K4.6
Aside from what I just mentioned above, the cooling fin pattern on the block, and the color of the heatsink, they are identical engines.
Old 05-10-2007 | 12:43 PM
lauderboy's Avatar
1st it's tuned fine
2nd the spur is tight
3rd 52/17 combo this was fine with my k .46
4th 30% nitro
so it must be the poor clutch pads so i will need so tips for a good alloy setup thats going to fit my flywheel or is that not a problem
thanks for the help guys it's ALL GOOD
Old 05-10-2007 | 04:29 PM
Vigilante212's Avatar
try 17/49 gearing. Also a nice aftermarket pipe will help. Nova aluminum clutches will fit also mugen makes some good ones.
Old 05-11-2007 | 10:07 AM
The Axial .28 overpowers and outperforms the K4.6 by a wide margin, so all of these "little" differences add up to make the Axial a better engine. Also, calling them the same engine isn't really fair to the Axial, nor is it technically correct. To me, it's like calling the LS1 and LS6 or the LS2 and the LS7 the same engines. Aside from being "small block Chevys" and having similar appearances, they are not the same engines in and of themselves. The differences between all of them distinguish them as their own and thus the same principle should be applied to the K4.6 and Axial. That's my stance on it and others should consider that as well so as not to mislead people.[&:]
You have to buy the optional turbo head button from Axial to run turbo plugs. You can't run a turbo plug with the head button the Axial comes with. Another overlooked difference, and quite significant in my opinion, is that the K4.6 exhaust port is "oval" on the inside of the block casting and round on the outside-it's necked down and likely a restriction. The Axial is round the whole way through and there is no change in port size.[8D]
Old 05-11-2007 | 10:18 AM
ORIGINAL: crazykat
No kidding. Mine was popping wheelies during break-in too when it was still quite rich. Now that it's broken in and leaned out, it wheelies all the time-I'm probably going to tune it to kill the wheelies and/or go with a 18 or 19 CB.
Old 05-11-2007 | 10:19 AM
ORIGINAL: Vigilante212
There's no need to go with a 49t spur. A 47t is plenty.[8D]
Old 05-11-2007 | 11:00 AM
lauderboy's Avatar
is the ofna alloy clutch anygood
Old 05-11-2007 | 12:40 PM
No, run mugen or STS shoes
Old 05-11-2007 | 01:57 PM
tmdz28's Avatar
ORIGINAL: gravediggerracing
i like the way you are thinking my good friend [8D]
Old 05-12-2007 | 06:57 PM
The ofna clutch shoes wear out fast. I have the blue ones and I think about 1/8" of them is gone
