Fei Bao Rafale (servo hatch)
Hi guys, I have been reading another thread on the FB rafale and they were discusing witch servos to use, they were mentioning JR 8411 among others and I just could not work out how they were getting them to fit, then I stumbled on a picture that had been posted and the hatch cover had a bulge in it. Mine are flat.[
] Only Mini sevos will fit, is this a modification, where can I get some covers with bulges?
hi mart1
please if you can post pic for rudder and canard servo positson, i have the same plane but i have no idea for it.
thanks
faisal
thanks
faisal
Don't use the stock linkage. It bad. Too much play and it put to much load on the side of the control horn.
Use better clevis on the horn and servo arm.
ORIGINAL: CARS II
The modified hatch cover should have come with your kit.
Tamjet thanks for the warning I will change the likage.
So is there somone that could source the missing modified covers for me? please!
ORIGINAL: CARS II
Mark
Check your hinges for any play and install the wing's hornes at least 3/4" away from the Aileron leading edge and when you are ready to glue the Ailerons make sure there is plenty of travel on both specially on the up position.
Mark
after a couple of emails sent to the guy I bought it from I got a reply saying that he had searched his wokshop and found them they had fell down the back of his shelf. My lucky day!![sm=biggrin.gif][sm=biggrin.gif]
My Feedback: (7)
OK, good.
The 8411/8611 or equal to them will fit just fine with a small modification to them, nothing big, the trick here is too set the servo flush against the bottom of the wing skin by cutting the servo "L" mounts to size, also you have to center the servo with the servo hatch before you drill the screws down, before all this cut or gind the corner that is touching the hatch to make it fit inside of it, so everything is in place before you screw it down.
My Feedback: (7)
I noticed that the hornes are already intalled on the Ailerons, you may have to do a modification when you get to mount the servos, if you noticed on the modified hatch the servo arm is to one side but on you wing the pushrod is was build more to the center of the hatch.
ORIGINAL: CARS II
