 EuroSport P160??? >
EuroSport P160???
EuroSport P160???
Old 07-24-2007 | 06:06 AM
UKR-Jet's Avatar
Default EuroSport P160???
Dear Friends,
It is possible to establish to glider EuroSport turbine P -160?
In me there can be the problems? Iam beginning Jet pilot! If you please help with the information.
Alex
Old 07-24-2007 | 03:07 PM
Banned
Default RE: EuroSport P160???
If your asking is a p-160 ok to use in a eurofighter ,??????
yes.. just don't head downhill at full throttle and pull hard, you can and will fold up the aircraft,
and it will give you great vertical and good high altitude performance.
most use a p-120 with great success.
It will glide if the engine quits but not that far, its a pretty Draggy aircraft.
Old 07-24-2007 | 08:46 PM
Edgar Perez's Avatar
My Feedback: (13)
160N size is great. I have one with a Rhino. Agree on the watch out about pulling G's
Old 07-24-2007 | 10:45 PM
My Feedback: (8)
I have a AMT 450(45lbs thrust) in mine. Lots of extra power. I did replace the stock tail pipe with a larger one. I had a Ram 1000 in it at first and I can't tell that it flies all that much different other than the extra power I am getting a 10 min flight on 1 gal of fuel. I am only full power going straight up. Have landed dead stick once and it floated OK. Mine is the old version so it is heaver(30lbs dry) than the new one. Hope this helps.
Old 07-26-2007 | 12:55 PM
Banned
I wish mine was 30 lbs dry....... I put to many toys on it....
