 F-16 setup: Elevons or ailerons-elevators ? >
Old 07-25-2007 | 04:27 PM
My Feedback: (51)
Default F-16 setup: Elevons or ailerons-elevators ?
Hello guys,
Im curious what does everyone think about this matter for the F-16 - whats better, elevons or ailerons\elevators ? and what are the differences ?
The reason im asking is that im building a Cermark F-16 turbine soon with some mods, and could modify the wing beforehand to glue the ailerons and fly on elevons, but i have not heard of anyone flying this setup with specifically a Cermark F-16 ??
To tset this we have set up my buddies' Cermark F-16 prop plane to test fly on Friday (it flew on standard setup to date) - what shall i expect from this setup ? any idea about the throws ? any tips are welcome..
And of course the most stupid question but one must ask, "aileron" input is like in the wings right ? i.e. right input - right elevator goes UP left goes DOWN ?
thanks for the help.
Old 07-25-2007 | 04:46 PM
Shok's Avatar
My Feedback: (28)
Default RE: F-16 setup: Elevons or ailerons-elevators ?
I have seen quite a few f-16's fly on elevon (not a cermark in particular) and they fly just fine
My Feedback: (17)
I fly a Skymaster F16 on tailerons and it is perfect, I can't compare with the aileron elevator version. I did that for two reasons , keep the weight down (saves two servos and linkages) and keep the plane simple to operate (nothing to plug when you bolt the wings).
I don't think one version is better than the other, just a personnal choice I guess.
For the throws you can start with 75% of the elevator travel for the roll function, it works like a delta or a wing so you're right.
Let us know how it goes with the prop F16
Florent
Old 07-25-2007 | 04:47 PM
vasek's Avatar
try mixing both (ailerons to elevons) on the Cermark prop f-16 , u'll love it! it should do great on the turbine setup as well
Old 07-25-2007 | 04:52 PM
My Feedback: (51)
vasek, whats the point in mixing both ?
Old 07-25-2007 | 05:37 PM
FalconWings's Avatar
My Feedback: (57)
Fly it per the instructions. There is no need to change the flaperon set-up, the model flies great as is. Really, this plane is a no brainer.
In my book an F-16 without flaperons simply looks stupid! But that's just me. Whatever you do, make sure you re-apply heat to all Momokte covered surfaces. Ak me how I know!
Good luck!
David
Old 07-26-2007 | 12:52 AM
vasek's Avatar
http://www.rcuniverse.com/forum/m_52...tm.htm#5274553
Old 07-30-2007 | 07:25 AM
My Feedback: (51)
Guys,
We flew the F-16 Prop by Cermark this weekend on just elevons, and even close to full travel ailerons, the aileron feeling was kinda mushy, so i think we would be better off with this specific plane on a elevon + wing ailerons setup, Right ?
