 Graphic Removal >
Graphic Removal
Graphic Removal
Old 07-28-2007 | 10:52 AM
FL510's Avatar
My Feedback: (8)
Default Graphic Removal
Any suggestions on removing old pro-mark graphics from a clear coated surface, without sand paper. Rubbing alcohol works, but it takes alot of "RUBBING". Looking for any other ideas.
Jed
Old 07-28-2007 | 10:59 AM
Default RE: Graphic Removal
I would try 'Varsol", a paint remover and then MEK if you can get it. I found it removes just about anything I didn't want removed. Powerful suff!
Old 07-28-2007 | 11:02 AM
bcovish's Avatar
My Feedback: (8)
3M makes a product called, Cleaner Adhesive remover. Safe for clear coat
Part #8984, quart can or #8987 spray can. Get it at a store that sells automotive refinishing products.
Old 07-28-2007 | 12:29 PM
FL510's Avatar
My Feedback: (8)
Thanks for the replies gentlemen, I had some MEK sitting around, worked great! The decal melted, the plane melted, and my liver melted[:'(] . It didn't mess with the clear coat, and at least I only had one stars and bars to remove.
Jed
