 Elan, which servos would you go with 8411 or Hitec 5645 >
Old 10-07-2007 | 02:11 AM
My Feedback: (54)
Default Elan, which servos would you go with 8411 or Hitec 5645
Has anyone been using 5645 on jets? how reliable are they compared to the 8411 or 8611? could there be any problem in using the hitecs with a spektrum receiver? I was thinking of using the hitecs on the flaps and rudders and 8611s on ailerons and elevators on the Elan. What about voltage regulators, would it be better to use a 5.1v , 6.0v or any other. Any advise would be appreciated.
thanks, Luis
Old 10-07-2007 | 04:31 AM
Default RE: Elan, which servos would you go with 8411 or Hitec 5645
Same sort of question, How does the resolution of a 5645 compare to a 5625.
Is it better because of the higher torque which must mean lower gearing or worse because of possible back play due to the lower gearing?
John c
Old 10-07-2007 | 04:57 AM
My Feedback: (167)
I just installed two Hitec 5955's on my F-16 and flew a couple of flights using the Spectrum 9000 receiver. Works great!!
There are quite a few servos on the Elan. If you use Spectrum, then you probably want to use a 6 volt regulator to keep the voltage as high as possible. After doing some fairly low tech testing on my F-16 I determined that I could get a 1/2 volt drop in voltage with very extreme movements of the sticks at the same time. This is probably never going to occur but it was also with only three digital servos, the Elan uses eight.
At the time I was using 5.1 volt regulators and could get the voltage to drop just below 4.5 volts momentarily. I am now using 6.0 volt regulators in the F-16 so if I lose a 1/2 volt I am still at 5.5 volts (instead of 4.5 volts). The regulators are the same price, you might as well use 6 volts!! It is a margin of safety, not to mention the fact that you get an increase in available torque with higher voltage.
Given my testing, even though it is somewhat primitive, I would be a little concerned using eight servos on 5.1 volts. I have been using a small Powerbox on the rest of my jets that use a lot of servos; i.e. Bandit, A-4, and soon my new Elan. I have never had so much as a glitch and I am approaching 150 flights on the Spectrum systems now. If you don't want to spend the money on a power supply I would at least use 6.0 volt regulators. Just my experience so far!!
BTW, you can buy the 5955TG servos at Servo City for $85.00 right now...Gary
Old 10-07-2007 | 05:29 AM
rcguy!'s Avatar
My Feedback: (69)
I use a bit different setup. No regulators at all. I use 2pcs 5 cell NimH packs. For the Elan I would go with 2000Mah each. Dual switch harnesses and plug the "extra" battery in an unused servo port or thru a "Y" harness on the retract or brake channel. I've seen to many failures due to inadequate regulator rating. No need to isolate the packs either! I recommend the NO BS elite cells at 7mh. Keep it simple.
The Hitec 5645 would do fine...BUT the JR8411's will give stomping performance!
Dave
Old 10-07-2007 | 09:18 AM
My Feedback: (51)
Yeah that's right keep it simple. We have tons of flight's on the Elan using 5645 ailerons but we did put a 8411 on the elevator and also unsing the Jr. ST126 on the flaps.
Old 10-07-2007 | 02:14 PM
My Feedback: (54)
thank you for your input guys, anyone else have any good suggenstions for a good setup on the new Elan??
thanks, Luis
Old 10-07-2007 | 08:29 PM
BlackCloud's Avatar
My Feedback: (12)
You may want to take a look at Hitec's 5985 over the 5645. That would be more on par with an 8411.
Old 10-07-2007 | 10:05 PM
I say keep it simple with a Smart-Fly Turbo Reg w/ failsafe switch , Smart-Fly Power Expander EQ10, and dual 7.2v 2200-3300 Li-Poly packs.
That's my idea of keeping it simple, and redundant.
Old 10-08-2007 | 08:33 AM
My Feedback: (14)
ORIGINAL: Gary Jefferson
Hi Gary, they were $85.00 till sunday morning. After read the price here in RCU, went to the webpage again at afternoon, and incredible, price went up to $114.00 again. No special for me, and I get stocked making my servo list.[:@]
Rgs
Alex
Old 10-08-2007 | 06:18 PM
Edgar Perez's Avatar
My Feedback: (13)
5955 for $89 at [link=http://www.airwildpilotshop.com/MoreInfo-1.asp?title=product&id=188]Air Wild Hobbies[/link]
5985 for $75, same place
Old 10-09-2007 | 12:34 AM
i use 8411 on my b/boomerang elevator and rudders and 8511 on my ail
Old 10-10-2007 | 03:02 AM
Henk Visser's Avatar
Hi,
I will go for 8411 on the elevator and al other futaba 3305 just as alan his Elan.
Old 10-10-2007 | 02:17 PM
My Feedback: (54)
ORIGINAL: G-ROOKIE
HEY G ROOKIE, ARE YOU USING SPEKTRUM?? CAN YOU TELL ME WHAT YOU ARE USING AS FAR AS BATTERIES, ANY REGULATORS, WHATS LINKED TO WHAT? I'M STILL DEBATING WETHER TO BUY A SPEKTRUM MODULE FOR MY 10X OR TO BUY A 9303 2.4
THANKS, LUIS
Old 10-10-2007 | 04:44 PM
My Feedback: (8)
I am using Futaba S3305 servos on everything in my Boomerang XL except gear valve and brake valve. These servos are 99oz of torque on 4.8V and are all metal gear. Got mine for about $35 each. They perform very well for me and I know they would be great in an Elan as well.
