 2.4 Ghz in Jets ? >
2.4 Ghz in Jets ?
2.4 Ghz in Jets ?
Old 10-08-2007 | 09:52 PM
Ed
Default 2.4 Ghz in Jets ?
What is the most robust, and dependable 2.4 Ghz system being used in jets today ?
> Jim
Old 10-08-2007 | 09:57 PM
Default RE: 2.4 Ghz in Jets ?
Jim,
You have opened up a crap-storm, so ready yourself.
I personally use Spektrum 2.4, and have not had any problems. I am comfortable saying that Spektrum is the market leader in terms of the amount of people using them.
Old 10-08-2007 | 09:58 PM
limeybob's Avatar
my DX7 in a JetMach, has been flawless so far.
Bob
Old 10-08-2007 | 10:15 PM
B58
My Feedback: (43)
Bunch of flights on my Baby Boomer with xtreme module in my 10X. Perfect performance. Bob
Old 10-08-2007 | 10:16 PM
My Feedback: (15)
I have had no issues on my DX 7. I feel very confindent in this solid system.
Old 10-08-2007 | 10:18 PM
Ed
Now when you guys say Spektrum, are you using the AR-7000 with 1 remote Rx, or AR-9000 with 2 remote Rx's ? Or more ?
> Jim
Old 10-08-2007 | 10:24 PM
bcovish's Avatar
My Feedback: (8)
I'm using the Spektrum module in a JR 10X, AR 9000 RX with one remote. About 25 flights with no issues in my jet.
Old 10-08-2007 | 10:49 PM
rcguy!'s Avatar
My Feedback: (69)
DX7 with AR9000 RX using 2 remotes and the monitor in a TitanSE powered KingCat. Dual 5 cell 2000Mah NiMh packs thru 2 switch harnesses directly into the RX. NO REGULATORS. 60 perfect flights. Rock solid! Never any frames lost and of course, no holds. Average less than 60 fades per antenna.
Dave Rigotti
Old 10-08-2007 | 10:59 PM
ORIGINAL: bcovish
Exact same system here, around same amount of flights too....working flawless
Old 10-08-2007 | 11:02 PM
Ed
Ok ............ How about batteries, 4 or 5 cell packs, and typically what size ?
Old 10-08-2007 | 11:17 PM
My setup:
Two JR 6v 5cell ni-cad 1800mah packs
Two JR switches
Bat-share
Power consumption= 300mah per 8 minute flight
ID:	779300   Click image for larger version
Old 10-08-2007 | 11:27 PM
ORIGINAL: SinCityJets
Jim,
The JR/Horizon/Spektrum reps only participate in these forums for support, you will never see them get into it with anyone.
I think you will find customers posting their true experiences here, and offer some very good feedback for those who are considering switching to 2.4 Ghz.
Old 10-08-2007 | 11:40 PM
HAMMERDOWN's Avatar
My Feedback: (100)
Spektrum module, 10X and AR9000 w/two remotes in Flash with about 15 trouble free flights.
Old 10-09-2007 | 12:05 AM
Jim Cattanach's Avatar
I am using Extreme power systems in all my jets & it is working perfectly. I did have a problem early on, but it turned out to be a bad cell in a battery pack.
I have a friend who has had nothing but trouble with his Spektrum set ups. For no apparent reason the servos go backwards & forwards from one extreme to the other, with no input from the Tx.
Old 10-09-2007 | 12:10 AM
I'm using to 2 - 2 cell 3300 Mah LiPoly packs
Old 10-09-2007 | 02:06 AM
My Feedback: (10)
ORIGINAL: GeeBeeJim
> Jim
i am using both with no problems
Old 10-09-2007 | 02:33 AM
My Feedback: (54)
Does the DX7 with the AR 7000 have enogh channels for the Elan? if so, what is the best way to hook things up. Or should I just buy a module for my 10x. In any case, can someone please post some good ideas for radio install. Any advice would be appreciated.
thanks, Luis
Old 10-09-2007 | 03:42 AM
My Feedback: (10)
ORIGINAL: Hornet 1
thanks, Luis
get the module system and the 9000
you have 9 channels to use
you can then als activate both valves for the jet-1a LG
Old 10-09-2007 | 04:43 AM
Not one futaba user yet! Interesting.
Old 10-09-2007 | 05:48 AM
Ragz's Avatar
im a futaba user...and awaiting some feedback on the 2.4g systems. I believe no one has ever flown a jet with the Fasst system yet. Not sure if people have tried modules from spektrum on futaba..dont know if they are compatible.
Old 10-09-2007 | 06:51 AM
rhklenke's Avatar
My Feedback: (24)
ORIGINAL: a cowell
We're still waiting for the full line of Futaba equipment. I have a 6EX we've been testing and it works great. I also have a Futaba 7 channel module/RX on the way from Tower. We'll test it extensively in some prop planes and then move it to the jets. Finally, if all is OK,a new 12 channel Futaba will be procured
From what I've seen, it will be worth the wait, and it may be that by the spring, Futaba will have the only 12 & 14 channel 2.4 GHz radios on the market...
Bob
Old 10-09-2007 | 07:55 AM
msrcflyer2's Avatar
My Feedback: (40)
No probs on my 10X module -R9000 w/ one remote. 15 flawless flights on my bandit HOWEVER..........
I have experienced issues when switching back and forth from 72 mhz to the spektrum module on my 10X.
EXAMPLE. Fly 72 Mhz with my another jet and then go fly my bandit on spektrum - switching the module, modulation and model selection on my 10x - it reverses the al, rud and elv.
I have been told there is a way to modify this, but have not been able to achieve this yet.
Any suggestions are welcome.
Old 10-09-2007 | 09:21 AM
cairoman's Avatar
I have had nothing but ISSUES with the AR9000, since I purchased it, last January. Even Last Sunday at the field, as soon as I would switch on, all the surfaces would jitter and dance around (just like interference on PPM modules does), gear retracting and collapsing etc, etc.
I have changed receivers (I bought new ones at Jetpower), changed remote receivers, even whole module/receiver packages. I tried the system with my PCM10X as well as my Graupner MX22. Same results. The monitor would show 576 frames lost in less than two seconds.
I purchased an XPS system, which I am installing in tonight and will see what it does tomorrow. I know Jascat has had ZERO issues with it in his PCM9, so I'll give it a try.
In saying that, I have a DX7 in my electric airplane which has been totally successful.
Chris
Old 10-09-2007 | 03:07 PM
Bob.R's Avatar
Unfortunately, a reported success here or failure there is not much more than anecdotal data. A broad and accurate survey sure would be nice, but that ain't gonna happen. I installed an AR9000 module in my jet (9303 transmitter) with two remote antennas and it has performed acceptably well since installation about 6 flights ago. I know this for sure - I get far fewer fades if the transmitter antenna is oriented vertically, FWIW.
Old 10-09-2007 | 03:41 PM
I am using a Futaba FASST 7ch module in my FF9c, in a Hanger 9 Funtana 90, with no problems at all, so far. I am only using a 4cell, 1100mah nicad for RX power with all digital servos, & have no issues with it. But I will need a lot more, trouble free, flights to convince me to committ it to jet power. Then I will consider the Futaba 12, on 2.4Ghz, rather than the add on module system. Ray.
