Dubro prop balancer
Old 06-08-2008 | 09:45 AM
My Feedback: (7)
Default Dubro prop balancer
Can somebody that has the Dubro Tru-Spin prop balancer tell me the length of the shaft the cones slide on?
I can't seem to find any specs anywhere.
I have the original High Point balancer, but the shaft is too short to work on a 3 1/2" spinner. Thanks
Old 06-08-2008 | 11:27 AM
tail strike's Avatar
Default RE: Dubro prop balancer
5.5"
Old 06-08-2008 | 11:30 AM
Big_Bird's Avatar
The shaft is 5 1/2" long and it is 3 5/8 between the black plastic bearing supports.
Old 06-08-2008 | 12:27 PM
I recomend the TF magnetic balancer over the dubro. And yes I have both. I learned to put bigger, longer, rods between the magnets for carrying heavier props and spinners. Now my TF balancer has three different weights of rods and can balance props from 6" to 30" and has balanced a 6" aluminum spinner.
Old 06-08-2008 | 01:05 PM
My Feedback: (67)
Hello ALTAVILLAN,
What do your rods look like that you use to balance your props up to 30 inches. I cant get my TF to hold my 22in & 23 in props.
NEDYOB
Old 06-08-2008 | 04:33 PM
Jezmo's Avatar
AV, can you post a pic? We like pics...pics are gooood.
Old 06-08-2008 | 08:05 PM
I made the base rods a bit longer and made the balance rods longer too. More mass equals greater carrying cappacity. My rods are 1/8" 3/16" and 1/4". The PT prop weighs 6+oz. The 6" spinner is 7+ oz. Much more than a 22x8 wood prop.
ID:	966732   Click image for larger version
Old 06-08-2008 | 09:59 PM
My Feedback: (67)
So what are the mesurements of the bottom rods and what is the mesurments on the rod holding the CF prop??
NEDYOB
Old 06-09-2008 | 08:36 AM
The balance rods are now 6 3/8". Your local hardware store will have piano wire in these sizes. Knocking the flux off welding electrodes will work also.
