2wd RS4 3
Old 05-11-2003 | 04:50 PM
Default 2wd RS4 3
I have a Rs4 3 and was wondering if anyone had found a way to make it rear wheel drive, but be able to switch back to 4 wheel mode. Whould that make its top speed increase?
Old 05-11-2003 | 05:00 PM
Default 2wd RS4 3
Take out the front dog bones, and center front dog bone. Voila - 2 wheel drive.
You need to think about the fact that you will also only be able to brake using the rear wheels, so you'll be easily thrown into a spin when you hit the brakes.
I see no reason to think that going to 2 wheel drive will increase your top speed. The only advantage would be a slight reduction in drivetrain losses, which I can't imagine will result in any difference in top speed.
If you want to increase your top speed, change your gearing.
Old 05-11-2003 | 05:08 PM
Default Re: 2wd RS4 3
I wouldn't bother, if you want more top speed, get a good pipe. If you want more than that, gear it up. If you want better acceleration, get a new engine.
Old 05-12-2003 | 11:49 AM
Default 2wd RS4 3
the little hex screw fell off my frontend of the spur gear so it's been 2WD ever since, well until i buy another screw, but trust me, since it's been 2WD i've never played with it, spinning out and TRYING to go straight will be all you're doing, i mean, it will go straight, but have fun turning unless you're so slow you're almost stopping. and no it doesn't increase speed
Old 05-12-2003 | 06:39 PM
Default 2wd RS4 3
alright thanks
