RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
is it okay to run an unbalances tire?
Old 10-11-2009 | 05:14 PM
Default is it okay to run an unbalances tire?
well, as you might have seen on of my other threads, on of my pede;s tires is totally unbalances (half the tires foam is in one bundle in the middle of no where). will this cause any problems other than shaking?
Old 10-11-2009 | 05:55 PM
sheograth's Avatar
Moderator
Default RE: is it okay to run an unbalances tire?
Depends how hard you're running, it will definitely cause premature degradation of the tire. You're also risking uneaven wear and increased vibration stress on the hub, axle, and joints.
Old 10-11-2009 | 06:07 PM
how do you know its all in a bunch? better question how does it get like that when its around a rim?
Old 10-11-2009 | 06:48 PM
Brainanator's Avatar
you sure it just isn't water in there? (maybe the foam ripped)
anyway, it could also wear out your bearing faster, and make it less stable.
Old 10-11-2009 | 07:57 PM
yeh i think their is water in them.. how does a foam bunch up if its a complete cicle around a rim
Old 10-11-2009 | 07:59 PM
well, i tried to drill a small 1/8 hole in the rims. 3 went good, 1 wasnt so great. anyways, this one deflates much faster when pushed with a hand, and when deflated, it feels solid, by that, i mean it feels as if there is no foam. should i buy foam or a new tire? anddo masher 2000's fit on 2.8 inch all star rims? thanks
Old 10-11-2009 | 09:38 PM
rclugnut10's Avatar
mashers won't tho i'd get proline badlands 30 if you're looking for a good offroad tire
basically you'll vibrate your car apart which will cause a lot more wear on parts than you'd think i'd at the very least i'd try deglueing one side and use like a screwdriver to get the foam back in line
the lug
Old 10-11-2009 | 11:48 PM
new idea, can i temporarily get the foam out and do some repairs with some packaging tape?. i guess it will reduce the wobble by a bit.. no LHS over here
Old 10-11-2009 | 11:51 PM
gelbschnee's Avatar
Does anyone have a link to a tire balancing guide thread or something similar?
Old 10-11-2009 | 11:59 PM
ORIGINAL: gelbschnee
Here's a video guide
http://www.youtube.com/watch?v=dtdXDstLr7s
Old 10-12-2009 | 12:02 AM
gelbschnee's Avatar
Thanks.
Old 10-12-2009 | 09:40 AM
Thanks.
no problem
