Upgrading Maverick XB
I have the electric maverick xb 1/10 buggy and would like to get new gears, batteries and maybe a motor too.
The site i want to buy from is [link]http://www.wheelspinmodels.co.uk[/link] because I live in the UK. on the [link=http://www.wheelspinmodels.co.uk/car/category/Batteries-7-2v-Stick-Packs__17c/]batteries[/link] page i have found two batteries priced at £14.24 but one is 3000mah and the other 2200mah, is the later better somehow? I currently have a 22 turn motor with a 19 tooth to 64 tooth cog setup. Cogs are available from 17-29 tooth and i am thinking of either 23 or 25, is this okay without a motor upgrade. It says that the speed control unit can handle down to 13 turn motors, is any motor down to 13 turn compatible?
Thank you all for your help, any advice whatsoever will be of help to me
Tully
Tully
ORIGINAL: TullyK
Tully
Tully
Hello,
if i put the Orion 17t brushed motor but with a 17 pignon is safer then the 19?
And about the Spur gear, i must leave it original?because i've seen in LRP Homesite 2 kinds : 64 and 58
I have a maverick strada xb and I am going to put the strada xb evo s brushless motor into it but dont know what pinion is the best there is a 17t in it and want to know if I should change the gearing
