Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Equalizer II Confusion
Old 07-23-2006 | 12:02 AM
shakes268's Avatar
Default Equalizer II Confusion
Well,
Just burned up a 8611a - does the Equalizer set 3 points - center, end point positive and end point negative or does it set 5? It seemed to want to set 5 different points.
Old 07-24-2006 | 10:21 AM
Default RE: Equalizer II Confusion
Hi Shakes,
The Equalizer will only set three points, center and both endpoints. It will not set 5. Can you please explain why you think it was trying to set 5 points?
Old 07-24-2006 | 10:25 AM
shakes268's Avatar
Well, I figured it out when I did the 2nd wing. It was the end point hold being on and the fact I was trying to set them up with both servos connected - so, yea, I screwed up - learn experience here
Old 07-24-2006 | 11:28 AM
Hi,
I am sorry this caused a confusion. Please let me know if there is anything else I can do for you.
Old 07-24-2006 | 11:32 AM
shakes268's Avatar
Not your fault Bob, no reason to apologize. Once I got the hang of it, very easy to work with - I'm spoiled now, probably going to order another one to use on the elevators in a few minutes. It's definitely not as clunky as working with the mix in the transmitter.
