Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
PowerExpander Pro - Super Reg Problem
Old 05-07-2007 | 08:31 PM
Default PowerExpander Pro - Super Reg Problem
Bob, I installed a PowerExpander and Super Regulator into my existing 35% Extra that I have flown for a year with no problems. Everything worked great on the bench in the shop. I adjusted the output voltage to 6.05 v and I thought everything was cool. Yesterday at the field I flew one 10 minute flight because after 10 minutes my throttle went into fail safe. I landed. Immediately checked the loaded (1 amp) battery voltage which was 7.60 volts.
I let the plane (and me) cool off for about 30 minutes then tried to fly again. This time the controls acted like they were not getting power. Tonight in the shop I measure the output voltage on one of the re/black/white leads and got 4.76 volts! I also measured the output voltage on the ailerons and got 5.76 volts. The output voltage should have been the 6.05 volts!! Loaded battery voltage was the same 7.60 volts as yesterday.
I tried to adjust the output voltage up to 6.05 but it would only go to 5.91 volts. When I hooked up my test lead to an aileron output slot and turned the airplane and TX on, the voltage went crazy!! It was alll over the place!!
What has happened? Have both units gone bad? Should I send them back to you for replacement/and or checkup?
Thanks for your help in advance.
Bobby
Old 05-08-2007 | 09:19 AM
Default RE: PowerExpander Pro - Super Reg Problem
Hi Bobby,
I really don't know what could be happening. I am pretty sure if anything is wrong its just the SuperReg but I can send you both units. What kind of PowerExpander is this?
Old 05-08-2007 | 10:10 AM
Thank you for the quick response. It is the PowerExpander Pro for a JR 10 ch R2000 receiver. The regulator is a Super Regulator. I will return the units so you can inspect them upon receipt of the new ones.
My address is 640 Lakeside Dr., Vicksburg, MS 39180
Thanks again.
Bobby
Old 05-08-2007 | 10:14 AM
Hi Bobby,
I am out of the PowerExpander Pro right now, we are just starting to build them. I can send you a SuperReg immediately. I am going to Joe Nall so I will not be able to get you a Pro until I get back.
Old 05-08-2007 | 12:13 PM
Okay Bob. At least that will give me a chance to see if it is the regulator or the PowerExpander Pro that is at fault.
Thank you.
Bobby
Old 05-08-2007 | 04:49 PM
PropStriker's Avatar
My Feedback: (12)
Robert,
Will you have a booth in the Vendor area at Joe Nall??? Selling product maybe?
if so, see you there!
Larry
Old 05-08-2007 | 04:56 PM
Hi Larry,
Yes, I will be at Joe Nall. I will get in late Tuesday night. I am going to bring some stuff but not a huge amount.
Old 05-09-2007 | 09:29 AM
My Feedback: (16)
I should be there friday morning.
Want to come by, say hello, and thank you for a great product. (PE Pro)
See you then!
Old 05-11-2007 | 08:05 PM
Robert, well I changed out the regulator and - same problem. It looks like the PowerExpander Pro "gave up the ghost" so so speak. Please send me a replacement PowerExpander Pro when you have one. I will return the replacement regulaor and old PowerExpander Pro once I receive the replacement.
Thanks for responding.
Bobby
Old 05-21-2007 | 04:27 PM
Robert, how did the Joe Nall go? It looked like there were 5000 people in attendance!! BTW, I need to get my Extra up and running again. When do you anticipate receipt of more PowerExpander Pros to arrive?
Bobby
Old 05-21-2007 | 04:47 PM
Hi Bobby,
It was very good for me as I sold out of everything and had to take orders to ship when I got home. It was very crazy. Never seen anything like it.
I just got the PCBs to start these so it will be about 2 weeks. I will know better in a couple days. I wish I had better news. Let me look around here.
I know I have one that works except for 1 output on 1 channel. That might hold you over.
Old 05-21-2007 | 05:10 PM
Ok as long as there is nothing else wring with it and until the new ones are ready.
Again, thank you for the quick response.
Bobby
Old 05-23-2007 | 08:50 AM
My Feedback: (16)
Robert,
It was good to meet you at the Nall.
People were pulling you every which way so you may not remember.
I just want to thank you for a great product and thank you for your insite with using a IGN cut off and one switch for RX and IGN.
Old 06-05-2007 | 05:18 PM
Robert, I received the replacement PowerExpander Pro and installed it - it works!! My original Super Regualr was okay so I will keep it. I will box up both the old PowerExpander Pro and the new Super Regulator and return them to you for credit to my account. I will probably send them out on Thursday so you should receive them next week.
Thanks for great customer support.
Bobby
Old 06-05-2007 | 06:37 PM
Hi Bobby,
I am glad to hear this. I will look at the old PowerExpander when I get it.
Sorry it took so long.
Old 06-16-2007 | 10:02 PM
Robert, did you receive the old PEPro? If so, what did you find wrong with it?
Bobby
Old 06-17-2007 | 01:09 PM
Hi Bobby,
I did receive it but I am so busy right now that I have not had time to look at it. I will try to get to it sometime this week.
Old 07-16-2007 | 09:32 PM
Hi Robert, have you had a chance to check out the PowerExpander Pro?
Bobby
Old 07-17-2007 | 09:43 AM
Hi Bobby,
Yes, sorry I have been really busy. I don't know exactly what is wrong but when a load is applied the voltage into the unit drops quickly. One side can take about 2.4 amps until its too low and the other side can't take much more than a few hundred milliamps before it drops out.
Old 08-01-2007 | 09:48 AM
Robert: so, the unit is defective? I suppose you can either credit my account or sent me a replacement unit since I already paid for the one you sent me to keep my plane going. Is that OK with you?
Bobby
Old 08-01-2007 | 09:55 AM
Hi Bobby,
Did you buy this from someone else? I don't have a record of you buying it from me. If so I will send you a new Pro.
Old 08-01-2007 | 04:57 PM
Yes I did. I'll dig out the receipt and FAX you a copy.
Bobby
Old 08-01-2007 | 05:10 PM
Hi Bobby,
Thats OK, I just need to figure out where things came from. I will send you out a new Pro today.
Old 08-01-2007 | 05:58 PM
Okay. thanks Robert. I'm home now and found the invoice. It is No. 3888 dated Apr 4, 2007.
Bobby
