Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
help for first 100cc setup
Old 09-16-2009 | 05:04 PM
My Feedback: (9)
Default RE: help for first 100cc setup
Thank you Robert,
Do you have regulator (Smart-Fly ) I can modify the voltage to 7.4V out to the servos?
My requests it can be difficult, But (PowerBox Royal(Servo voltage: 5.9 V or 7.0 V, selectable) Can do this.[&o]
Regard
Meshari
Old 09-16-2009 | 05:17 PM
Hello Meshari,
No, we do not. The problem is you fly down to 7.0V on the Li-ion batteries. Regulators have a dropout voltage. When you batteries are below 8.0V you are not going to get 7.0V out of the PowerBox, it will be less. They are not telling you the whole truth. When you get down to 7.0V on your batteries you are going to be getting about 6.0V out of the PowerBox.
Old 09-16-2009 | 05:31 PM
My Feedback: (9)
all right!
Now some servos In the market For example, (JR 8711HV Servo (High Voltage) and Hitec HS 7950TG HV Servo - 486 oz-in at 7.4v and Seiko servo PS-050) They accept 7.4v
What the best system to use them to get benefited from the halo power When to Use 7.4V?
Old 09-16-2009 | 05:39 PM
My Feedback: (9)
halo power When to Use 7.4V? = lots of power When to Use 7.4V?
regard
Meshari
Hi Meshari,
When a servo is rated at 7.4V this means it can handle the full voltage of a 2S lithium pack (7.0V-8.5V). If you use our PowerExpanders the servos will get the battery pack voltage and these servos are fully compatible with that. Any of our PowerExpanders with Deans connectors (Pro, Competition 12 or Eq10) will work with a 2S lithium pack and these servos.
Old 09-16-2009 | 05:43 PM
  #31
Hi,
I am not sure what you asking. The higher the voltage you run servos on the more power they produce and the faster they are.
Old 09-16-2009 | 05:55 PM
  #32
My Feedback: (9)
Now I am understand
I thought when you said (What ever voltage you put into the PowerExpander Eq10 and Pro will go to the servos) the out of V is 15 (7.4X2) lol
Yes, I need PowerExpander
Which one of them the most suitable for me Eq10 or Pro? Or What is the difference between them?
Best Regard
Meshari
Old 09-16-2009 | 06:04 PM
  #33
Hi Meshari,
The Eq10 has servo matching, the Pro does not. The Competition 12 does not have servo matching but does have a built-in Ignition Cutoff.
Old 09-16-2009 | 06:24 PM
  #34
My Feedback: (9)
Thank you Robert,
After what I experimented with Smart-Fly products now I adore it
Best regard
Meshari
