RCU Forums
-   Smart-Fly (Quest Engineering) Support Forum (https://www.rcuniverse.com/forum/smart-fly-quest-engineering-support-forum-328/)
-   -   Bat Share (https://www.rcuniverse.com/forum/smart-fly-quest-engineering-support-forum-328/5625753-bat-share.html)
Josey Wales 03-27-2007 03:53 PM
Bat Share
Hi Robert..will using the Bat share eliminate the common ground shared between the two packs ?
rrritchey 03-27-2007 04:21 PM
RE: Bat Share
Hi Joe,
No, using the BatShare will still result in a common ground. When you use two battery packs to connect to a common receiver you will always have a common ground. There is no way around this. Even when you use regulators and switches you end up with a common ground.
Please let me know if you have any other questions.
Josey Wales 03-27-2007 04:22 PM
RE: Bat Share
Ok..thanks for the fast reply
