Full Build Guide - 250 FPV Racer
This is my complete FPV racing building guide. I made these videos to make it easier for beginners to easily find all the information. My number one priority is to make it affordable. Post any questions below!
#1 Assembly of the frame, mounting the motors, installing the flight controller and soldering bullet connectors. https://youtu.be/WZllJ0xpPX8 #2 Installation of the FPV system, soldering the main power leads and binding the transmitter to the receiver. https://youtu.be/w16vG2DusnM #3 Programming the flight controller (CC3D with OpenPilot). https://youtu.be/mUMe8CLf3Bc #4 Assembly of the FPV goggles (Quanum V2), and installing the FPV system. https://youtu.be/81BjBVdH7Us #5 Charging batteries and test fly. https://youtu.be/0laOuITbDPM All the parts used in my videos will be listed in the description of the video. However, here is the full parts list: Frame: http://carbix.se/product.html/carbix-... Flight Controller: http://rctimer.com/product-1285.html Brushless Motor: http://rctimer.com/product-1128.html Propellers: http://www.surveilzone.com/Dalprop-2-... Electric Speed Controller: http://rctimer.com/product-1134.html Antennas: http://rctimer.com/product-1090.html Transmitter and Receiver: http://www.hobbyking.com/hobbyking/st... Turnigy Nano Tech 1300mah 3S 25-50C: http://www.hobbyking.com/hobbyking/st... FPV goggles: http://www.hobbyking.com/hobbyking/st... Video transmitter + camera: http://rctimer.com/product-1276.html Video receiver: http://rctimer.com/product-1129.html IMAX B3 Charger: http://www.ebay.com/itm/131662747700?... Heat Shrink Tubing: http://rctimer.com/product-711.html Heat Shrink Tubing (big): https://www.hobbyking.com/hobbyking/s... Mounting Pads: http://rctimer.com/product-913.html LED-strip: http://www.hobbyking.com/hobbyking/st... 22AWG Wire: http://www.hobbyking.com/hobbyking/st... 16AWG Wire: http://www.hobbyking.com/hobbyking/st... Bullet Connectors: http://rctimer.com/product-335.html Helping Hands: http://www.hobbyking.com/hobbyking/st... XT60 Connector: http://www.hobbyking.com/hobbyking/st... Cable Ties: http://rctimer.com/gallery-141-b,11-0... 1.5mm Hex Screwdriver: http://www.hobbyking.com/hobbyking/st... Lipo Battery Voltage Tester: http://rctimer.com/product-569.html |
| All times are GMT -8. The time now is 09:11 AM. |
