Multiplex ROXXY BL Control 9100-12 Opto
FL
Roxxy BL Control 900 -Serie - New with Programmer V2 No.3302/4 (Used) ($75.00 for all)
(Retail Price $250.00) plus programmer.
Note: The Roxxy BL Control 900 -Series is completely new with Deans around mount. The V2 programmer is free.
Handling and Shipping $9.95 Priority Mail.
Contact: [email protected]
ROXXY 9100-12 Opto Brushless Speed Controller
Universal speed controller for brushless motors. Aircraft, helicopter, ship and car models.
One for all. Choice of forward - reverse operation, with or without brake. With speed control function in heli mode.
Recommended accessories:
Programmer V2 1x 8642
with fan cooling.
The ROXXY-BL 900 controller series is particularly characterized by the fact that it can be used universally for almost all areas of model making. Be it as a forward-reverse speed controller for RC cars or ships, as a speed controller for racing boats without brakes, as a flight controller with adjustable brakes or even for e-helicopters with or without speed controller. The generation of 900 speed controllers masters everything and at a reasonable price.
With the introduction of new transistor and manufacturing technology, the performance of the 900 ROXXY ESC series is significantly superior to conventional devices.
Compared to the previous series or competitor products, the operating time is doubled. For example, the 950 regulator - in full load operation - can process a battery capacity of approx. 4500 mAh continuously with 50 amps without thermal overload.
Features:
Forward-backward programmable, ideal for marine or car model applications
Governor mode, programmable with or without speed controller, perfect for micro and mini e-helis.
Optional programmer for easy and clear setting of functions.
Optionally convertible to indoor or outdoor operation, display via LED.
brake that can be switched on and off by programming.
High clock speed (32000 Hz) for sensitive control, e.g. when "torquen"
An integrated temperature protection protects against thermal defects.
Programmable undervoltage shutdown
Like all controllers, these are equipped with the usual protection and filtering features, such as POR tarnish protection and RX filters.
Adapted to the BL motor series ROXXY, but can also be used for other BL motors, as there is almost no restriction on the number of motor poles with these controllers.
The type series is designed for different cell numbers:
Std: 6-12 NC/NiMH - or 2-4 LiPo.
Type-6: 6-18 NC/NiMH - or 2-6 LiPo.
Type-12: 14-36 NC/NiMH - or 4-12 LiPo
Programmable basic functions, can also be set without a programmer:
Battery Type: NC/Nx or LiPo
Engine running direction left, right, forward-backward.
Brake on - off
Model Type Selection Flight, Ship, Car or Helicopter
Additional functions (can only be set with Programmer No. 8642)
Adjustable cut-off voltage for Nx cells approx. 0.9 V / cell
Adjustable cut-off voltage for lithium batteries 2.75..2.8 volts/cell
Shutdown mode
Engine timing
Acceleration
Start power
Braking force
Governor (Speed Controller Mode)
with fan cooling.
Features:
Brake on - off
Shutdown mode
Engine timing
Acceleration
Start power
Braking force
