Jeti esc calibration
Hi guys,I bought a used JTM viper 90mm with stumax fan and jeti esc, and I'm using an ix14 radio, I need to throttle calibrate my esc, cause I have to move the throttle stick to almost half throttle to start the motor, and I think that I'm not getting the full throttle when I move the stick to full!!! Can anyone help me with this issue
My Feedback: (15)
just in a general way,
most brushless esc can be throttle calibrated by:
first remove the prop, then
turn on tx and,
a. set throttle stick on tx to high
b. plug battery in to energize the rx/esc
c. when it makes a beep sound, lower the throttle stick to low.
it should now give the cell count beeps and be ready to operate properly
you can do a test with the prop removed to see if the range is more appropriate now, would not go to full without the prop installed, if i were you.
turn on tx and,
