Go Back  RCU Forums > RC Boats > Speed - Electric
 Prop Advice >
Prop Advice
Speed - Electric For all your electric boating needs.
Prop Advice
Old 09-28-2010 | 05:08 AM
Default Prop Advice
Looking to pickup a balanced and sharpened prop.
25" HOTR mono, 3660 3000Kv motor, 4mm stinger drive, wire drive, 3S 2200 in parallel.
I also have a 380XL (2868) 2898Kv motor.
May swap in a 4074 2000Kv Leopard.
I have been running a 42 dia prop without much pitch. Its plastic and Im rounding/jumping the drive dogs (thats with previous motor).
Here is the prop I have been using (went thru 3 of them now):
http://hobbyking.com/hobbyking/store...op__42x29x15mm.
Here is a video of it with that prop before destroying it.
http://www.youtube.com/watch?v=6YY5m8BphFU
Old 09-29-2010 | 07:29 PM
Default RE: Prop Advice
Nobody?
Im thinking of an X442?
Sound good or to big? I intend on buying a sharpened balanced prop as I dont have the skill to do it myself. Ideally I would like to buy just one of course. I know there has to be people out there that have used this hull with similar power and should know.
Please help
Old 09-29-2010 | 09:12 PM
shenlonco's Avatar
Hi i have a brushless apache 24 with a 3300KV motor runing 3S i use the x430 and 432 props a 442 sounds way to large like you are going to be burning up your lipos and heating everything up with that size prop.
Old 09-30-2010 | 06:43 AM
Advice I have received on OSE is to try X437/3 and X440/3 and the Graupner 40 & 42
Im going to go ahead and try the 3 blades. Searching for balanced/sharpened ones right now.
