hello newbee here
My Feedback: (20)
ORIGINAL: siberianhusky
I was sort of indifferent to electrics until a running buddy of mine got a used sv, stuck a 2300kv motor in it and a bigger esc, ONce we figured out the right prop and got things adjusted that boat rips. LOL I have gutted an older nitro hull and am doing a 4s mono! He changed my attitude with the SV. Good boat!
these can be a lot of fun when setup of right like yours
TX
What is CF?
ORIGINAL: srt10
In my opinion not much needs upgraded on an SV boat
A good prop is always good.. I like using a CF45 and CF48 prop
I've also heard a S230 and S235 work amazing on this boat
And good lipos with a C rating of 30c and higher will give the boat more punch and speed with the bigger props
And always check your temps when you use a bigger prop to make sure things are running in the safe zone
And punch it!
ORIGINAL: jride1999
ok thanx.i wanna upgrade my bat,everything is stock sept grim racer prop.im new to elect boats,always owned nitro car an this is my first boat. if i upgrade my bat,do i need to change anything else?
And punch it!
