Brushless suggestions
I have a old Kyosho Jet Stream I would like to get running again. At this point I only want about 30+ mph. What would be a cheap combo for this boat?
Also any prop suggestions would be welcome.
NY
i'm not experienced enough to suggest a prop, but i can suggest a velineon combo if you're just looking for thirty, it works good for me, youll just need to keep an eye on your esc temps or rig up some watercooling for the esc, its real easy to do
Yes, the AquaCraft SV27R or ProBoat Stiletto motor/controller combos will work great in that hull. Start with a prop like an x440 or x442 depending on your batteries.
