Hyperion EOS0606i AC/DC Charging NIMH??
Hey guys I am looking for some help.I purchased the charger as stated in the topic.I am trying to charge the nimh batteries I have. 8.4v 3000mah.At what rate can I charge the battery pack at??I was told 3 amps max.Also I tried to charge at 0.3 amps and the voltage after 10 minutes read 9.012 volts??Is this normal??But the Mah was very low.Im guessing I should charge at 3.0amps??Anyone know???Any input would be appreciated.Thanks guys.
Check out hangtimes hobbies- good info. 3amps would be 1C which is a fast charge for nimh I think. Check out hangtimes though
Thanks checked it out and answereed alot of my questions.However I do have some other questions.One of my batteries was charged to 2915mah and the other to 3107mah is this normal??Also both batteries fully charged now are holding 10.1-.10.2 volts.however each battery is rated for 8.4v should i be worried???
yeah i read up a little on the subject last night fully charged each battery is about 10.2v however since the ESC on my spartan crapped out on the first maiden run out of the box i dont think i will be holding onto it.Any suggestions??looking for something large 36inches minimum,electric,rtr for $420 shipped??any suggestions??
I'm a plane guy but there are several good threads on rc universe answering exactly that question.<div>I think miss geicko? Or something did well. The spartan was slated to hell- you might get a replacement esc for free as so many people have done the same.</div><div>Apparently the spartan hull I okay bit the electrics are not.</div><div>Depending in how handy you are you could upgrade the motor esc and prop? Offshore electrics is a good place to start</div>
Thanks I called Castle today and they said they would send out a ESC to me.They said the've had this problem before It seems as this is common and I have 30 days to send back the old one after receiving my replacement.So Im gonna try that and see if the hull is worth holding onto for now.Well see they werent able to tell me if ill have it for this weekend or not.I am hoping for the best.Wish me luck!!
