Go Back  RCU Forums > RC Boats > Speed - Electric
 equipment- lost or ????? >
Speed - Electric For all your electric boating needs.
Old 01-12-2013 | 11:20 AM
Default equipment- lost or ?????
I sent for jet equipment and used paypal and paid on Dec.15,2012 and today is Jan.12,2013 and still no equipment. No tracking or postage insurance emails were recieved.
Old 01-12-2013 | 12:19 PM
Default RE: equipment- lost or ?????
You can cancel the payment on PayPal. If too much time has passed contact PayPal and they can cancel it. If the goods ever turn up you can then pay. I have my PayPal account linked to my credit card for another layer of protection
Old 01-23-2013 | 07:13 AM
Enter a complant with PP they will contact the seller . Check out what PP can do for you on there site .
Old 01-23-2013 | 10:30 AM
grimgard's Avatar
ORIGINAL: Mikeup
I sent for jet equipment and used paypal and paid on Dec.15,2012 and today is Jan.12,2013 and still no equipment. No tracking or postage insurance emails were recieved .
As others have said contact PayPal asap! They will sort it our for you. I had a dispute and used PP and I got my money refunded. They shipped the item to the wrong person....
From PayPal
13. Protection for Buyers.
13.1 Types of Problems Covered. PayPal Purchase Protection (also known as PayPal Buyer Protection) helps you if you encounter either of these problems:
You did not receive the item you paid for with PayPal – “Item Not Received†(INR), or
You received an item you paid for with PayPal but it is “Significantly Not as Described†(SNAD) (as described below)
If your problem is a transaction that you did not authorize, please use this form to report the unauthorized transaction.
An item is “Significantly Not as Described†if it is materially different from what the Seller described in the item listing. Here are some examples:
You received a completely different item. For example, you purchased a book and received a DVD or an empty box.
The condition of the item was misrepresented. For example, the description when you bought the item said “new†and the item was used.
The item was advertised as authentic but is not authentic.
The item is missing major parts or features which were not disclosed in its description when you bought the item.
You purchased three items from a Seller but only received two.
The item was damaged during shipment.
An item is not Significantly Not as Described if it is materially similar to the Seller’s item listing description. Here are some examples:
The defect in the item was correctly described by the Seller.
The item was properly described but you didn't want it after you received it.
The item was properly described but did not meet your expectations.
The item has minor scratches and was listed as used condition.
Source
[link]https://cms.paypal.com/us/cgi-bin/?cmd=_render-content&content_ID=ua/UserAgreement_full#13. Protection for Buyers.[/link]
Old 01-23-2013 | 11:10 AM
Everything worked out with seller. I had the 50 amp esc you have and it shelled out. Sorry about drive parts. Put that new motor on on 3S. higher amp esc. What size esc do you have in the other boat. 2900kv x 11.1 = 32190rpm.WOW, bring a change of pants along in case of fallout,LOL! You'll find out the sharp turns need caution for spin-outs. Congrats!!! You're getting to know boating pretty good, video when you can will be fine. Prop for it is a tough call. Being you've got a high rpm on 11.1, i'look at Offshoreelectrics props in the carbon fiber section, Find the correct rotation props and i'd say a 633 which is a 6 pitch. Higher the rpm, lower the mm size by 1 or 2mm like going to 435. Now a higher pitch has a force cone which is small while a lower pitch has a bigger force cone and disperses the force over a wider area. I'll look up Offshore.Lookup carbon s series- 2327.33 which is a 6 pitch and see how that works out for controlability of boat with the high rpm status. They seem to workout real well for me. I just ordered a 2370 bl (brushless) from Kershaw motors and will run on 3S with rpm at 26307. Spare>-I checked on my Arpro 1 prop and i have a y535 metal prop on 3S and located in props at Offshore in y series section.
s
Old 01-23-2013 | 12:05 PM
grimgard's Avatar
I am going to run the stock 50amp with the 2900kv with the 3s and hope for the best lol! On my Shark I am using a Turingy 60amp ESC . It should be super fast with this set up If the 50amp dies from to much voltage I'll just get another 60amp turingy esc they are only $30.00 http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
I'll have to look into those props your using thanks!
Old 01-23-2013 | 03:08 PM
is this for the Jet boat?
I ran some cheaper 50-60 amp ESCs in it first, but they kept burning out, so then I went overboard and got the Turnigy Aquastar 120amp, never looked back
Old 01-23-2013 | 03:25 PM
No it isn't!
Old 01-23-2013 | 04:13 PM
ah OK, disregard it then
