32 inch tunnel
NS, CANADA
32 inch tunnel
i have a 32 inch tunnel hull with the stileto outdrive an 1800 kv motor on 5s with a x442 prop 120 amp esc and my motor burnt up today what would be a more suitable motor.
a 2500 kva motor with 3 cell lipo and a 438 prop eill give you your 52 mph i use 5000 mili amp 40c lipo batteries only make shure your esc is programed for the motor
ON, CANADA
1600-1800kv is not a bad choice for 5s LiPo. The motor just needs to be larger in physical size to handle the excess waste heat you are producing with that prop load. Look at a 39mm x 74mm can size.
NS, CANADA
leopard 4074 is that what i need that is what i can find in my price range and i will need to cut a hole in my out drive top for that to work but that is ok
